Old 11-11-2015, 10:37 PM   #1
iostorm
Is the frame for a 67 the same as a 72?
Is the bare frame for a 67 c10 the same as the frame for a 72 c10? identical?
iostorm is offline   Reply With Quote
Old 11-11-2015, 10:41 PM   #2
bill3rail
bill3rail's Avatar
Re: Is the frame for a 67 the same as a 72?
I believe the power steering frames have a dimple in them where the pump mounts. Others will chime in on anything else.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 11-11-2015, 11:35 PM   #3
swamp rat
swamp rat's Avatar
Might be differences regarding rear Leaf springs VS Coil springs?
I agree on the P.S dimple, i hear some later run 67 frames got it before the 68 came out.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-12-2015, 07:35 AM   #4
midniteblues
midniteblues's Avatar
The rad core support mounts are slightly different on the 67-68.
Also the top of the frame rails in the engine bay are wider on a 67.
There is tabs welded too the front cross member for the disc brake lines. Where as the drum brake lines attach too the rear of the crossmember.
And the ps dimple.
All this can be worked around though too make any combo work.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
