Old 09-15-2003, 11:39 PM   #1
sbrban
charging system ?'s
My '71 burb doesn't want to keep the battery charged. I unhooked the battery cable and the engine died.I put on a new alt. and voltage reg but the truck still dies when the cables unhooked. Any suggestions on what else it could be? I've also replaced the starter/solenoid in the last 6 months.
you never have too many suburbans....
sbrban is offline   Reply With Quote
Old 09-15-2003, 11:40 PM   #2
sbrban
Oh yeah, the battery is an optima,maybe a year old.
Old 09-15-2003, 11:48 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Sounds like it is time to start chasing wires.
I would pull the alt off and have a parts store check it, most will do it for free. Also, the reg is cheap enough that you could just replace it (again) just to rule out a dead part even though it is new. (what are they...12 bucks?)
After that, it is time to start looking at wires and getting out the 'ole multi meter.
Old 09-16-2003, 12:00 AM   #4
sbrban
i changed the alt and reg and condensor off of another burb just to rule out the possibilities like you said.I was afraid of the idea of chasin' the wires-looks like it'll be a long night tomorrow.
Old 09-16-2003, 12:11 AM   #5
Longhorn Man
That's OK, i just discovered (at midnight) that mine isn't charging either. And There is no way I can call off or be late for work.
Looks like I'm hooking up the charger and crossing my fingers that there is enough light to drive by in the morning.
Old 09-16-2003, 02:09 AM   #6
Hooter
My other Love
Hooter's Avatar
is there a wire going from the distrobution block on your fender to your battery? if not I would try hook a wire fromt the distrobution block to the battery
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 09-16-2003, 02:20 AM   #7
ckenwright
ckenwright's Avatar
I agree with longhorn man..
I thought Ihad a charging problem also, but I think now it might be my ignition switch. I was installing dual electric fans the other day. While trying to find a good lead for the fan relay I noticed that on the output of the switch I had 6 volts with it in the off position. Nice huh?
ckenwright is offline   Reply With Quote
