11-12-2015, 06:25 AM | #1 |
ls swap
Any useful info welcomed on ls swap in a 68 short bed. As for radiator, trans cooler, wiring, Drivetrain, fuel system with stock in cab tank, anything helpful thank you
11-12-2015, 08:25 AM | #2 |
Re: ls swap
All the information you're looking for is over in the LSX swap section. I just finished my swap last spring. Best thing I've done to the truck.
11-12-2015, 11:16 AM | #3 |
Re: ls swap
As noted, there's an LS swap section here:
http://67-72chevytrucks.com/vboard/f...play.php?f=206 But I can give some quick answers to your questions. Radiator: I used the stock one, with 2005 Silverado hoses. Trans cooler: The one in the stock radiator works unless you're doing something crazy (or have reason to suspect it's full of crud). wiring: Lots of options here. You can run an aftermarket standalone ECU (that's what I did), run a stock ECU with a professionally made engine swap harness, or a stock ECU and mod the harness yourself, depending on your needs, skills, and budget. Drivetrain: If you want an automatic, a good option is to get the engine with its matching 4L60E or 4L80E transmission as a set. You'll have to modify the driveshaft to make it fit. You can get just about any transmission that fits behind a small block Chevy to go behind an LSx if you want. Fuel system with stock in cab tank: Yes, it's doable; I stuck a Walbro 255 lph fuel pump intended for a Mazda Miata in my stock tank. If I did things again, though, I'd use a tank mounted under the bed as I still sometimes have a gas smell in the cab and I don't like that. Plus, an electric in tank pump is pretty loud - a pump under the cab would probably have been a better choice, but I wanted to see just how easy a low buck in tank fuel pump conversion would be.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
12-03-2015, 10:19 AM | #4 |
Re: ls swap
We make bolt-in conversion radiators and we also offer a forum member discount:
http://67-72chevytrucks.com/vboard/s...d.php?t=590670 We can build it for any engine set-up including the LS (no additional charge) and include a free steam port and built-in trans cooler if needed. |
12-03-2015, 11:14 AM | #5 |
Re: ls swap
Another good place to research are the build threads. There are a ton of great LS builds going on right now. Good luck.
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
12-03-2015, 03:20 PM | #6 |
Re: ls swap
http://67-72chevytrucks.com/vboard/s...d.php?t=468341
Here's my build thread for my 68 short/wide. -Josh
1967 Buick Special wagon 1968 Jeep Wagoneer 1958 Chevy Panel Truck 2017 Suzuki M109R |
