![]() Join Date: Jun 2013
swapping front crossmember?
would it be better to use 63 front x member or change to 73 and up x member if end results will be dropped spindles and disc brakes, already have 63 member in driveway,just thought i read the late model had better bushings,any advice,info greatly appreiciated
#2 | |
Re: swapping front crossmember?
I like the 73-87 better as it's easy to go down to the discount auto parts store and get parts when needed, not to mention they are cheap to get.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
I'm sorry it's a 1964 c20
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
There would be no point in swapping out your 64 crossmember for a 63 crossmember.
Additionally, 73-87 parts are less expensive.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
Doing swap for 6 lug as well
![]() Join Date: Sep 2006
You need to swap out the C 20 cross member if you are going to 1/2 ton suspension. The lower control are bolt up differently. You can use any cross member from 63 up to 87. The later model cross members need a few holes drilled oblong.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
yea thats the reason for the swap, already have 1/2 ton rear in, a little intimidated when it comes to the front...
Oh, okay,
If you want 6-lug, then the 63 crossmember would be the simplest swap. Should bolt right up.
Although. ECE sells spindles that allow you to use 6 lug rotors on your C 20.
Looking to convert your ¾ ton Truck to ½ ton front suspension? We are proud to introduce the only C-20 to C-10 2½" Drop Spindles available on the market. (disc brakes required). Over the years, we’ve had many customers with C-20 8-lug Trucks that would like to convert over to the better riding C-10 suspension and change their wheels to either a 5-lug or 6-lug bolt pattern. These new Conversion Spindles allow you to upgrade to C-10 front disc brakes on the ’60-’70 model Trucks, and give you the option of 2½" front Drop Spindles for the same price without having to change your tie rods and ball joints. http://www.earlyclassic.com/catalog....gory=Drop+Kits
#10 | |
