09-15-2003, 11:46 PM | #1 |
Pronounced "Pew-al-up"
Keeping the truck
Well after careful consideration, and some pressure from my wife and alot of the members on this board I have decided to keep the
truck, and AMP up the engine a bit!! I really love the truck, but havent been motivated to really get going on it, but I think I am getting a second wind. My question is this. I have a buddy that is going to loan me his engine stand and an engine puller and I want to pull my engine and tranny and have my tranny rebuilt, and all my engine MOds done. I have a friend that will rebuild my tranny, but I want to do the Cam, intake, timing chain, HEI, and Carb. I own a manual for our trucks but havent done a Cam change before. Is this something that is fairly easy to do in my garage by myself? Is there any instructions out there on a website or something that will assist me?? I am also going to paint the block and put my new Oilpan on . Just trying to get some confidence before I start. I can figure stuff out real good, but am going to have pressure from the wife to get it done and out of the garage!!! Any help would be greatly appreciated, and would keep me in good standing with the wife as well....
Classic GM Trucks of Washington Club Member 1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's, Power Locks, Truck Photos |
09-15-2003, 11:52 PM | #2 |
Formerly yellow72custom
If the 350 has 125k on it, i don't think i would do to many HP upgrades. While the motor may run fine and last awhile longer, it is proably starting to get tired, and has blow by. I would do a compression test, or even a leakdown test to see what kind of shape the bottom end is in. If the numbers aren't great, i would look into pulling the engine and rebuilding it. If they are still strong, putting in a new cam wouldn't be a bad idea.
I would go to a large book store and get a book on building SBC's. I bought "How To Build a Small Block Chevy for the Street" and i like it OK. I bought it mostly because all the pages were full color . Any good high-performance book should have detailed instructions of changing a cam as well as hopping up the rest of your motor, or completley rebuilding it if it needs it.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
09-15-2003, 11:59 PM | #3 | |
Bloo
with the 350 in Bloo (see "Mutt 350" i bought a block and bottem end out of my friends basment and totally guessed how to rebuild it, it amazed me when i started it the first time
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
09-16-2003, 12:01 AM | #4 |
While i have only done a head swap before, it does feel good haveing something start right up that you have tore down and put back together .
Feels alot better than paying someone else to do it, and cheaper too.
09-16-2003, 01:30 AM | #5 |
Thanks !!!yellow72custom , I just bought the book on Amazon.
Will those numbers as far as compression and leakdown show on a dyno test? I had a Dyno done a couple thousand miles back, and the shop stated that the compression was real good. I can stomp on it and get no blue smoke, but from time to time I will get a little puff when I first fire it up in the AM
Classic GM Trucks of Washington Club Member 1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's, Power Locks, Truck Photos Last edited by DanoDMano; 09-16-2003 at 01:41 AM. |
09-16-2003, 08:37 AM | #6 |
Mike
If you kept the oil changed,and you have good compression,I would do a cam swap and intake.Change the valve seals on the heads.Might be where your puff of smoke is from,if it is oil smoke.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
09-16-2003, 09:27 AM | #7 |
Smoke in the morning isn't bad at all, this means you need valve seals as smokekiki stated. I would still do a compression test though....buy a compression guage from the auto parts store (the screw in type works better) and check the compression. The book you bought has instructions on performing the test, as well as normal numbers if i remember correctly....
09-16-2003, 09:55 AM | #8 |
Post Whore
Glad your keeping that truck. It is outstanding. Good luck on the upgrades.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
09-16-2003, 04:36 PM | #9 |
Man I love this place, I always get good answers, and more info than I could imagine. Is it alot of extra work to do the valve seals while I am doing the Cam???
I just drove down and got the engine hoist from a buddy of mine, and the stand will be here soon!! I am getting psyched to get this done!!! Thanks for the help, and the compliments!!!!!
09-16-2003, 05:02 PM | #10 |
hey DanoDmano I am trying to PM you and your inbox is full.
Thanks Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
09-16-2003, 05:15 PM | #11 |
I dont know why?? I have no PM's at all??I guess I need to talk to the administrator??
You can email me at Daniel.E.Ritola@Boeing.com Thanks, Dan
09-16-2003, 05:21 PM | #12 |
DANO--- CAM & LIFTER CHANGE, ALONG WITH A INTAKE & CARB CHANGE, & REPLACING VALVE SEALS IS PRETTY RUDIMENTARY STUFF. IT'S A GOOD START ON A MECHANICAL LEARNING EXPERIANCE. THERES AN AWFUL LOT OF PEOPLE HERE THAT WOULD BE MORE THAN HAPPY TO ANSWER ANY QUESTIONS THAT YOU MIGHT HAVE. JOHN
P.S. GLAD YOU'RE KEEPIN THE TRUCK
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
09-16-2003, 08:00 PM | #13 |
Half a bubble off!
Glad to hear you're keeping it, good luck with the motor upgrades! Take lots of progress pics, maybe they can help someone in the future.
Just call me LB. '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
09-16-2003, 08:13 PM | #14 |
I plan on posting alot of photos while I do it, and I'll probably be asking alot of questions too!!!
09-16-2003, 08:45 PM | #15 |
Dano....didn't know you were considering getting rid of it....glad your keeping it!
Let me know when you are ready to do this and I would be happy to help.
FocuzTech Performance Evergreen Protective Coatings Gatorhyde...the best kept secret in spray in bed lining & protection |
09-16-2003, 09:43 PM | #16 |
Hey Mike I pm'd Ya. I dont know why it keeps telling me my box is full. I have no PM's!!!!
09-16-2003, 09:50 PM | #17 |
I would check all of your folders including sent.
09-16-2003, 11:09 PM | #18 |
Designated Grumpy Old Man
Dano, before you tear it all apart how about showing up this Sunday at the issaquah triple X meet. Seet the board meeting section for details.
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
09-16-2003, 11:14 PM | #19 |
I'll be there!!! Just dont mind the paint chips, it is my
daily driver and not show worthy by any means!!!
09-16-2003, 11:30 PM | #20 |
Good luck!!
If you are going to do valve work, think about better heads. A better breathing engine will impress you. Older Corvette .202 heads are decent.
If you aren't set on rebuilding the engine, a good remanufactured engine from Bowtie Performance in Sumner cost me $895. All new TRW parts, with the mods I wanted (heads, RV cam, new style one piece seal, 4 bolt main). I'll be at the XXX - see ya there. (I touched up my paint chips today). good luck, scott
Silence is golden, duct tape is silver. - Scott |
