11-12-2015, 10:50 PM | #1 |
buddy buckets frame and console
up for grabs is a buddy bucket frame and console. lower seat part of console, mounting hardware will need to be repaired as it is loose and not attached. has the brackets to fasten console to framework all 4 pieces.also includes the 4 pieces of brackets to mount passenger non adjustable seat to framework. 300.00 obo plus the ride. thanks michael
for my yoke is easy and my burdens light. J.C. matthew 11:30 Last edited by fergi62; 11-12-2015 at 10:55 PM. Reason: added dialogue |
11-13-2015, 12:08 AM | #2 |
Moderator
Re: buddy buckets frame and console
FYI this setup is out of a Dodge. The bucket seat you have listed in another thread matches this setup.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
11-13-2015, 12:23 AM | #3 |
how can you tell?
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
11-13-2015, 01:52 AM | #4 |
11-13-2015, 02:09 AM | #5 |
Moderator
The front bar on the frame is also indented slightly, as well as the center leg. Here is a pic. True also on the upholstery pattern.
11-13-2015, 08:44 AM | #6 |
thanks guys, i wasn't sure about the set up. but a question is the center console and seat the same as gm other than the covering? this was actually bolted in a 65 gmc custom cab truck with all 4 bolts fastened down to floorboard. could this be for the 64-66 truck instead? thanks michael
for my yoke is easy and my burdens light. J.C. matthew 11:30 |
11-13-2015, 12:08 PM | #7 |
you might want to also take a pic of the end bracket with a measuring tape beside it. Looks to be taller.
I bought a set of Dodge buddy's and they are nearly identical and can be made to work in our trucks. I've seen many different end bracket combinations though.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
11-13-2015, 12:34 PM | #8 |
Moderator
They could be out of a 66 GMC, if they bolt directly in to existing floor holes. That frame looked just like the Dodge ones, as did the upholstery.
11-13-2015, 01:03 PM | #9 |
I don't think they are Dodge, the outer side plates are all the way out on the frame and the Dodge outer side plates are 4 or 5" in unless they made a couple of different styles http://67-72chevytrucks.com/vboard/a...1&d=1416720957
11-13-2015, 01:31 PM | #10 |
How much to ship to 95660. Thanks
11-13-2015, 02:01 PM | #11 |
1967-1972 Chevy truck buddy bucket seat frame for reference.
Scott |
11-13-2015, 02:01 PM | #12 |
member #16
Here's some c/10 king posted pics of 1966 gmc buddy buckets.
http://67-72chevytrucks.com/vboard/s...d.php?t=488386
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
11-13-2015, 07:36 PM | #13 |
they don't look like dodge. the upper part of the outer bracket on dodge seats are about 5" wide and the tube frame goes thru the bracket. on the one that I have anyway.
11-13-2015, 10:06 PM | #14 |
i will have to box it and check it then. are you also interested in the single seat i have for it also? i had it listed in another post because i thought it was for a 69-72. here is the pics of it.
11-13-2015, 10:22 PM | #15 |
Yes I'm interested in the seat too
11-13-2015, 10:26 PM | #16 |
What happen to the other seat ?
11-13-2015, 10:38 PM | #17 |
The frame and center set/console are 66 GMC. The frame is taller and there is no center support the center seat and console are also different, it's a one year only.
I have a 66 GMC with factory buddy buckets and a 68 buddy buckets that I put into a 65.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
11-13-2015, 11:02 PM | #18 |
"Trucks with Class"
[B]Here's a nice set of driver's side sliders, that are NOT 67-8. Maybe someone can use them putting together that seat. Are they '66?
$60 shipped??? Or trade for 69-72 bucket seat brackets. /B] Last edited by PICKMUP; 11-15-2015 at 11:44 PM. |
11-13-2015, 11:04 PM | #19 |
How much for the seat tracks?
