Old 09-16-2003, 12:21 AM   #1
dr_erni
tranny leaking / dropping out of gear
my truck has been sitting for a couple months in the summer time and there was a puddle of oil under it...
when i drove it.. it felt like it was dropping out of gear while driving.
also i had to rev it a couple times before it would catch reverse...
this is my winter vehicle and they're predicting snow tonite!!!!
any ideas???
thanx
dr_erni is offline   Reply With Quote
Old 09-16-2003, 12:24 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Is it an Auto? If so, check the fliud, it may just be low....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-16-2003, 01:24 AM   #3
dr_erni
yeah... it's an automatic, forgot to mention that.
i'm worried about it leaking though... is there an additive for first aid?
what should i be looking at to stop the leaks
Old 09-16-2003, 07:32 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
There is an additive that's supposed to soften the seals up. I have never used it, so I can't say if it works or not. Tranny fluid is pretty thin. If it has been sitting a while, it might seal up a little on it's own with some driving...
Old 09-16-2003, 09:22 PM   #5
1FaastC10
1FaastC10's Avatar
dropping out of gear? sounds like the grim reaper has ahold of your trans...
1FaastC10 is offline   Reply With Quote
Old 09-17-2003, 03:02 AM   #6
TIMSPEED
TIMSPEED's Avatar
naw, mine did the EXACT same thing. Just make sure it's got fluid, the fluid is HOT, and that the vacuum line that goes from the Modulator to the intake is in tact and connected.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 09-17-2003, 09:33 AM   #7
1FaastC10
1FaastC10's Avatar
Tim, the modulator line doesnt control wether or not, or how well the clutches are engaged, it uses vac pressure to work against governor pressure to tell the trans when to shift. this has nothing to do with engaging the gear, just tells it when to change gears. i'd put my money on either worn out clutches or a southbound pump.
