Old 11-12-2015, 11:16 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Yellowing/stain removal for a coolant tank
I located a very cool rare as heck original (dealer add on) coolant expansion tank. It's got some yellowing and a few stains on the exterior, but super nice. Has half a sticker left, so NOS left in the open, early take off and/or off a clean truck.
My first instinct to clean was fine sand paper. Now I'm thinking baking soda in water and fine steel wool. Even white vinegar. Anyone with experience knows what works best? The goal is like new or close, and of course no damage. Thank you.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 11-12-2015, 11:39 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Yellowing/stain removal for a coolant tank
I would not use either sandpaper or steel wool. They will alter the original texture. I'd start with a kitchen cleanser such as Comet, which contains a mild bleach, and a damp terry towel rag. If you want to be a bit more aggressive after trying that, try a brass bristle brush with the cleanser. Be gentle with it though.
FirstOwner69 is offline   Reply With Quote
Old 11-12-2015, 11:53 PM   #3
71CHEVYSHORTBED402
Sounds good.......Thank you. But I'm thinking nylon brush.
O
\___/
Tony
Old 11-13-2015, 12:53 AM   #4
ho70
ho70's Avatar
Mr Clean magic erasure works great on vinyl, give it a try
ho70 is offline   Reply With Quote
Old 11-13-2015, 01:01 AM   #5
71CHEVYSHORTBED402
Interesting "Cleans textured surfaces, plastic patio furniture and alloy care wheels."
Tony
Old 11-13-2015, 02:01 AM   #6
leddzepp
Moderator
leddzepp's Avatar
Muriatic (pool) acid. Wear gloves and a respirator (do not breathe the fumes)
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 11-13-2015, 07:37 AM   #7
midniteblues
midniteblues's Avatar
They all sound like great ideas for cleaning out the tank.
When I did the one in my Pontiac I cleaned it out real good and filled it with bleach. It helped some of the yellowing.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 11-13-2015, 03:37 PM   #8
cdowns
cdowns's Avatar
me i'd use some crc swish it around and then rinse with warm water
Old 11-13-2015, 03:57 PM   #9
Ochre Ogre
Ochre Ogre's Avatar
I second the magic eraser, that's how I cleaned mine. Also cleaned of black over spray from PO "detail" job
1971 C10 Cheyenne 350/350
Ochre Ogre is offline   Reply With Quote
Old 11-13-2015, 05:32 PM   #10
jayoldschool
Moderator
Westely's Bleche Wite. If you can get the old formula, it's much better.
jayoldschool is offline   Reply With Quote
Old 11-13-2015, 11:14 PM   #11
71CHEVYSHORTBED402
Someone recently told me white vinegar is diluted Muriatic acid. I just looked it up, it's diluted acetic acid. Muriatic acid is diluted hydrochloric acid. That said, white vin. might work also, it's just not as strong. I have a bottle of each. Thanks.
Incidentally, from what I can tell, all stains and discolor are on the outside of this bottle.
Tony
