1986 Wiper Motor Ground
My 86 C10 wiper motor does not park in correct location. I have read several posts on this site and it seems the most likely culprit is poor ground. It is mentioned that there is a ground strap, but mine doesn't have one that I can see. The motor is mounted with bolts going into the firewall with rubber spacers on them. How is the motor supposed to be grounded? Thanks in advance for any advice.
Re: 1986 Wiper Motor Ground
Try to ground the motor case with a jumper wire. if this works there ya go. From what I understand, one of the rubber grommets are lined with a ground connection.
good luck
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE |
I ran a jumper from the motor case to the battery ground and it still stops where it wants. I'll keep checking previous posts. Thanks
Do you have your switch grounded? Check out my posts below, it shows how to test
http://67-72chevytrucks.com/vboard/s...d.php?t=688229
My wiper switch is in the column with the turn signal lever. This acted this way when I first got the truck and I have since replaced the column with a rebuilt tilt column and new wiper switch and it still does it.
Moderator
![]() Join Date: Oct 2008
The wiper motor park function is controlled inside the motor itself by the park switch. If the wiper motor is properly grounded through the dash switch then the parking switch failed. It's inside the motor gearbox. You can repair the motor parking switch or buy a rebuilt wiper motor.
There's an extensive windshield wiper motor troubleshooting guide in the 1986 GM light truck service manual. It starts about halfway down PDF page 1277.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 10-17-2016 at 09:43 PM. |
same problem here
http://s7d9.scene7.com/is/content/GenuinePartsCompany/1232577pdf?$PDF$
This is a napa bulletin that might help |
