11-13-2015, 11:20 AM | #1 |
Steam blowing in cab
I just got my heater core changed and now im having steam blowing into my vents. Anyone have any idea what that could be? thanks
11-13-2015, 11:23 AM | #2 |
laying low
Re: Steam blowing in cab
Its probably a damaged New heater core.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
11-13-2015, 11:55 AM | #3 |
You may have punctured the new heater core with the screws that hold the brackets in the box.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
11-13-2015, 12:19 PM | #4 | ||
"I ain't nobody, dork."
Either that or one of the hoses is leaking and its getting inside the heater box.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
11-13-2015, 12:26 PM | #5 |
I don't think it's likely to be hoses or clamps, since those are on the other side of the firewall. Of course, if the foam insulation between the core and the firewall is missing, it's possible steam could get in there. It can't hurt to check to make sure the clamps are tight.
Best case scenario would be a factory-defective heater core (it happens). But as the others stated, it's also very possible you damaged it during the installation. I would remove it very carefully, so that if it is a factory defect you can have the part house replace it. |
11-13-2015, 12:40 PM | #6 |
I would think its the heater core,had it happen before,
11-13-2015, 01:34 PM | #7 | ||
Had a upper heater hose leak at the clamp at the heater core in a '67 C10 and coolant seeped into the box over the core... nice and foggy windows.
Gary
11-15-2015, 11:54 PM | #8 |
It was indeed a bad heater core! Thanks guys!
11-16-2015, 12:08 AM | #9 |
I'm sure that was something you didn't wanna do twice.
Had that happen on a 1st Gen s10 once. Not fun.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
