Old 11-13-2015, 06:21 PM   #1
solidaxel
solidaxel's Avatar
2003 5.3 4L60E Down shifting
When downshifting from 3rd to second and 2nd to 1st there is a noticeable "hard" down shift'
Is this something that is corrected with the computer tuning or is it in the transmission?
Up shifts are smooth and positive for all four shifts, but when slowing down for a light the 3rd to second is a bit too harsh???
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 11-13-2015, 06:54 PM   #2
boostedc10
boostedc10's Avatar
Re: 2003 5.3 4L60E Down shifting
Stock trans, how many miles, what's the fluid look like, where's the fluid level at, stock converter?
It's much easier to diagnose a trans in person where you can look at pressure and/or log it to see what's going on. Answering the above questions may help myself or other point you in a direction though.
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 11-13-2015, 07:00 PM   #3
solidaxel
solidaxel's Avatar
Stock trans 75K miles, fluid and filter fresh, top of stick ,converter is factory
LS 3 4L70E
Old 11-13-2015, 11:22 PM   #4
clinebarger
Do you have a different PCM laying around with the VATS deleted? Try that just to prove out that it is Tune/PCM related or not.
Anytime the Throttle is Closed the PCM will command the Lowest Line Pressure via the EPC solenoid. Which is 1.0 Amps of DC Current, Full Line Pressure is Zero Amps. This can be manually read with any Meter that can read Amps on the Positive(High) & Negative(Low) EPC wires.
clinebarger is offline   Reply With Quote
Old 11-14-2015, 05:07 PM   #5
solidaxel
solidaxel's Avatar
Yes we did switch computers first thing..........no change
O K, I am not sure where the EPC is located?
LS 3 4L70E
Old 11-14-2015, 06:07 PM   #6
boostedc10
boostedc10's Avatar
The EPC is in the transmission but you can read it on pins c (high) and d (low) of the transmission plug.
Old 11-14-2015, 07:09 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Is this only when you manually downshift, or does it happen on kickdown?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-14-2015, 11:13 PM   #8
solidaxel
solidaxel's Avatar
Normal! driving when you come up to a stop sign 3rd.....clunk 2nd 1st the rpm increase "a bit" and then seems like the (torque converter did not unlock)
but nice idle 700 rpm................. upshift through the gears throttle controlled and up into the torque kicking in 45+ mph just like my other truck 2003/ 5.3 4L60E
LS 3 4L70E
Old 11-14-2015, 11:14 PM   #9
solidaxel
solidaxel's Avatar
Thanks, I will have to wait on the empty rack to check that
LS 3 4L70E
Old 11-15-2015, 12:12 AM   #10
clinebarger
Do you have the TCC Brake wire hooked up/wired correctly?
Old 11-15-2015, 12:36 AM   #11
solidaxel
solidaxel's Avatar
Power to TCC until the brake is pushed
I will re check the cruise control wiring also
LS 3 4L70E
Old 11-15-2015, 12:39 AM   #12
solidaxel
solidaxel's Avatar
The tail lights are LED, if that makes any difference
LS 3 4L70E
