Old 11-14-2015, 07:23 PM   #1
68Timber
I know the pieces fit
68Timber's Avatar
New window regulator has a tight spot in it
I got new manual regulators from Rock Auto and they're AC Delco. But the drivers side has a tight spot in it when rolling it up. It happens at the same spot with the crank on every revolution. Glass is not installed yet, I was just running it up/down to get the lithium grease everywhere. I see a little bit of leeway in the mounting bolts, is this something I can adjust out or do I need to box it up and send it back? This is my first time replacing manual regulators, the passenger side is loosey goosey slick like you'd want it.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 11-15-2015, 09:03 PM   #2
68Timber
68Timber's Avatar
Re: New window regulator has a tight spot in it
Boxed it up to return it, got a replacement headed my way...
John
74 Honda Z50 build
