Old 11-15-2015, 10:39 AM   #1
LSGarage
LSGarage's Avatar
Front Drive Shaft Question
Lets see where to start. I'm working on my '67 GMC K-1500, 305 V-6, SM465 mated to a T-221 transfer case. Truck was an OEM drum brake truck. I got it with a (I think) '71 Chev disc brake front axle.
I just put my trans and transfer case back in the truck. Installed the front drive shaft and noticed that there is no spline exposed (see picture). I know that I need to shorten the drive shaft length. My question is should I shorten the shaft tube or could I get away with shortening the yoke that attaches to the front differential. The spline (on the shaft its self) is around 6" long but only 2 1/4" at the end has gear teeth cut into it. The rest of it is under cut.
Additionally I have no chassis or body lifts on this truck and I'm not going to use the 4WD for anything else other than getting around in the snow.
67 GMC 4x4, 305 V-6, 4-spd
86 S-10, 2.8 2WD LWB
01 Suburban (family hauler)
13 Honda CRV (wife's wheels)
03 Malibu (daughter’s car)
LSGarage is offline   Reply With Quote
Old 11-15-2015, 01:27 PM   #2
61K10
61K10's Avatar
Re: Front Drive Shaft Question
the two axles should be the same, Dana 44's. is the slip shaft bottomed out? you should have very little movement in the D/shaft. I would trim it if it was me. the experts will chime in with their fix.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 11-15-2015, 02:53 PM   #3
LSGarage
LSGarage's Avatar
Yea the slip shaft is bottomed out. Before I had the T-case rebuilt it was pushing a bearing out of the case. I originally thought it was because it has a 3:42 in the rear & 4:11 up front. Now I think the bear issue may have been caused by front drive shaft
Old 11-16-2015, 11:24 AM   #4
ryanroo
ryanroo's Avatar
it needs an inch and a half or so of exposed slip shaft. i would take the drive line to a driveline shop with a good reputation and have the tube shortened. its not a really difficult operation and should require no parts as long as everything is in good shape. maybe an hour of labor.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 11-16-2015, 01:43 PM   #5
LSGarage
LSGarage's Avatar
Thanks, ryanroo, for your response! Just needed a little reassurance about how to fix this.
Old 11-17-2015, 04:30 AM   #6
andrewmp6
If you don't have a local drive line shop try a big diesel shop most can make/work on a drive shaft.
andrewmp6 is offline   Reply With Quote
Old 11-18-2015, 06:14 AM   #7
LSGarage
LSGarage's Avatar
Thanks, andrewmp6, that's looks like the way I have to around here.
