Old 11-15-2015, 02:17 PM   #1
GTSideSwipe
Teach Mounting
So right now my C20 didn't come from the factory with a tach and I'm thinking about buying one and mounting it to the steering column but I don't want to drill any holes into the column. So my question is how did you mount yours and what tach did you get?
GTSideSwipe is offline   Reply With Quote
Old 11-15-2015, 02:42 PM   #2
68panelman
68panelman's Avatar
Re: Teach Mounting
My nontach trucks always got the hose clamp to column treatment.
68panelman is offline   Reply With Quote
Old 11-15-2015, 02:47 PM   #3
hugger6933
Re: Teach Mounting
a Worm gear type hose clamp about the 2& 3/4 size[measure first to be sure]. The tach will have a [for lack of better word]leg coming from the back that is screwed on to the center with a nut that can be loosen and turned to place it better. That clap can be opened up so far as to come apart then place the tach on the column and just tighten it up. Very easy about a .5 on the 1 to 10 difficulty meter.
hugger6933 is offline   Reply With Quote
Old 11-15-2015, 03:00 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Teach Mounting
Yup. Sun Super Tach II and a hose clamp.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 11-15-2015, 04:42 PM   #5
hamjet
hamjet's Avatar
Re: Teach Mounting
mounted with hose clamp protecting the column with supplied strip of rubber..
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 11-15-2015, 05:31 PM   #6
REEDS 72
REEDS 72's Avatar
Re: Teach Mounting
Black zip ties work well
REEDS 72 is offline   Reply With Quote
Old 11-15-2015, 05:35 PM   #7
EARNHARDT#3
EARNHARDT#3's Avatar
Re: Teach Mounting
Sunpro and hose clamp for me too. It's kinda cheesy but it's cool in a retro kinda way as well.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 11-15-2015, 06:56 PM   #8
GTSideSwipe
Re: Teach Mounting
Thanks everyone! Got a pro Tach at o'reilly's with a 2 inch hose clamp and some fuse box wire clips. Looks and works great. Engine idles at 800rpm.
