Gettin close
I got the replacment doors on and the bed moulding holes welded up over the weekend.
Little by little it's getting closer to being road ready. |
yeller
What are you doing in the pic...welding shut the stake pockets??
![]() Looking good! -Jeff |
Professional Grade
Wow, looks like my truck
I'm still just grinding things down, but soon will come the welding, bondo and much sanding... How did you get your wheel well trim off? all the little bolts in mine just stripped... Should I grind them on both sides and punch the little peice out, or should I grind them and leave the little peice in there as a neat little patch?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
#4 | |
All mine except one unscrewed, I just ground it off and puched it out. |
[QUOTE]Originally posted by bigblock73
[B]What are you doing in the pic...welding shut the stake pockets?? ![]() No there were a bunch of small holes up there may have had a camper shell or something at one time. |
| Bookmarks |
