Old 11-15-2015, 02:46 PM   #1
dfosh
Six cyl to v8 swap
What if any changes will need to be made to the wiring harness ? I have a 68 GMC 250 six cyl and want to change to 350 with hei . thanks
dfosh is offline   Reply With Quote
Old 11-15-2015, 08:22 PM   #2
Tony
Re: Six cyl to v8 swap
The HEI should be feed directly from the ignition switch...The fuse box has marked non fused ign terminals so you can wire it direct. Some say to use a #10 wire because the HEI can in theory draw 20 amps..... I have done it with a 10 and 14 wire and never noticed any difference....
Tony is offline   Reply With Quote
