Old 11-15-2015, 03:08 PM   #1
61K10
61K10's Avatar
spring experts
leaf spring front bushings for my 62k10. bought them from LMC and they are about 3/8" shorter than the org. ones. if pressed to the middle of the spring eye there is a gap on each side. Will this be ok?
also the springs leafs have worn spots in the adjoining leafs. can i dress these spots with a grinder? (I know i need new springs) not now.
just spent to much on this tk already.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 11-16-2015, 03:26 PM   #2
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: spring experts
Put spacer (washers) evenly on the sides and tighten up.
Grind a radius on the offending spring so it dosent wear into the spring above it.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
