Old 11-15-2015, 04:25 PM   #1
82crawler
82crawler's Avatar
Can't find horn contact part numbers
After hours and hours of troubleshooting and research, I've finally solved my horn issues. But I need 2 pieces and can't find them anywhere online. I can touch a wire from inside the turn signal cancel cam hole to the center of the column and my horn honks, as expected, I'm just missing a couple of pieces. Anyone have any ideas?
a) Horn Contact Ring (Mine is broken)
b) Brass Horn Contact / Plunger / Rod / Thingy? (Completely missing)
My current situation:
The part I need:
82crawler is offline   Reply With Quote
Old 11-15-2015, 04:35 PM   #2
franken
Re: Can't find horn contact part numbers
Try the help section at the parts store.
franken is online now   Reply With Quote
Old 11-15-2015, 07:01 PM   #3
chiefcfd
chiefcfd's Avatar
This should do it. Part #8.
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=133
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 11-15-2015, 07:07 PM   #4
GTSideSwipe
You can get a original turn signal switch here.
http://www.classicparts.com/mobile/1.../#.VkkPysvTnqB
GTSideSwipe is offline   Reply With Quote
Old 11-15-2015, 10:43 PM   #5
chevyblue72
if you look at the first pic near the bottom, there is a brass looking spring inside the housing. That could be your spring and button that fell out.
chevyblue72 is offline   Reply With Quote
Old 11-16-2015, 10:24 AM   #6
82crawler
82crawler's Avatar
Originally Posted by chiefcfd View Post
Yeah I saw that in my research, but that's actually the pin and spring kit that goes on top of the horn contact ring. I need the one that goes below it, which doesn't seem to show up on any part diagrams, but does show up on everyone's photos.
Old 11-16-2015, 10:25 AM   #7
82crawler
82crawler's Avatar
I actually don't need the turn signal switch, and none of the turn signal switches come with the brass pin that rides underneath the horn contact ring. However, I did find the horn contact ring at classicparts, something I haven't been able to find anywhere else. Now I just need that brass pin.
http://www.classicparts.com/mobile/1.../#.VknlkrerQdU
Old 11-16-2015, 10:38 AM   #8
82crawler
82crawler's Avatar
I'm not sure what that spring came from, it seems too small to work as the plunger spring. I didn't find any button down inside of there, though.
For the record I'm using a newer GM steering wheel and therefore won't be using the original style horn cup kit. Like this... (I'm just missing that plunger UNDERNEATH the horn contact ring.
Old 11-16-2015, 12:26 PM   #9
GTSideSwipe
Wait what? I replaced my turn signal switch last month and it had the brass contact. Where are you getting yours? They all come with one.
You must be talking about the replacement cancellation piece that has the two cancel spring's that are at most auto parts stores.
And it also looks like you have a tilt column... this is the correct switch assembly. They all have the horn contact pre installed.
http://www.classicparts.com/mobile/1.../#.VkoEK8vTnqA
Old 11-16-2015, 12:49 PM   #10
82crawler
82crawler's Avatar
Sorry about that, I must have been looking at the wrong part. Tried to edit my post afterwards but it was too late! I'd hate to replace the whole turn signal switch when all I really need is the brass contact. Mine is a non-tilt column, some of the pictures above aren't mine, just found them on the forum while searching. Is there a spring underneath that brass contact?
Old 11-16-2015, 01:03 PM   #11
GTSideSwipe
That's alright man, sadly though the only way I see it when that button wears out is to replace the whole turn signal switch. Its not exactly "original" but it is a original reproduction which is nice.
If you want, here's the switch for non tilt columns.
http://www.classicparts.com/mobile/1.../#.VkoL9MvTnqB
Old 11-16-2015, 01:50 PM   #12
82crawler
82crawler's Avatar
I gotcha. Is that button spring loaded? Seems to me like it would/should be.
Old 11-16-2015, 02:10 PM   #13
GTSideSwipe
Yeah, it is. You could try taking it apart and getting a new longer spring. Either way its the spring that is worn out. I was trying to fix this exact problem and it turned out its get a completely new turn signal switch or replace the worn out spring behind the brass contact. It was better in the long run to get a completely new turn signal switch.
