Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 11-15-2015, 07:52 PM   #1
lucifer
lucifer's Avatar
Cool 1965 Suburban or Short Truck chassis SOLD SOLD
1965 Suburban or Short Truck chassis with powertrain
Chassis was great condition when I bought it no rust or damage
Chassis was sandblasted and painted with POR 15
1986 C10 front suspension installed ( bolt it )
New CPP drop springs and drop spindles all new bearings
All new front end parts:ball joints, energy suspension bushings, tie rods
pitman arm , idler arm
All new brake lines throughout right to master cylinder
Matched master cylinder included!!
12 inch slotted front rotors with SSBC calipers
13 inch rear drums all new stuff
Moser axels in late model 10 bolt posi rear end.
3:42 posi differential
Power steering box refreshed
large front sway bar
unique rear sway bar
new gas tank 31 gallons
fuel lines with new filter/regulator combo
Rear static fill air bags
New trailing arm urethane bushings
New Ride Tech rear shocks
New Bell tech front shocks
Fresh LS1 short block with NEW LS6 heads ( not rebuilt NEW)
LS6 camshaft and LS6 intake, coil packs, wires, fuel rails and injectors
Corvette balancer and driver side brackets
Corvette hydraulic motor mounts
Low mileage 4L65E trans with fresh convertor
Complete dual exhaust 2 1/2 to back with Hemi turbo mufflers
New urethane cab mounts included
Chassis is ready for you body and ready to go
This chassis will also fit Short Bed trucks!!! ( cut 4 inches off rear frame rails)
All work was done 700 miles ago!!!
asking 9999.00 NEW LOWERED PRICE 7999.99!!!!!!!!! Pictures coming soon SOLD SOLD SOLD
Chassis with be at Turkey Rod run Daytona Beach in two weeks.
Chassis has wheels and tires on it for transport
call Scott 386 366 4244 or PM me here on forum
This picture gives you an idea of ride height and stance.
65 burb On the road Mar 26th Finally
lucifer is offline   Reply With Quote
