Old 11-16-2015, 10:30 AM   #1
jasnake65
1960 blinker return switch
Hello all and recently picked up a 1960 Swb fleet side. Came into a problem with the blinkers. They did work but now dont, the blinker return switch wasn't working and then no turn signal ar all. Removed the horn button and I can get the front blinker working. Sounds like it needs to be rebuilt or new parts...can't seem to find the part. Looking for some help. Don't want to buy the chrome blinker system you can install over the stock system.
jasnake65 is offline   Reply With Quote
Old 11-16-2015, 12:08 PM   #2
creep
Registered Loser
creep's Avatar
Re: 1960 blinker return switch
They have switch repair kits and turn signal cancelers.
http://www.classicparts.com/Switches/products/206/2/0
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 11-16-2015, 06:30 PM   #3
joe dirt
joe dirt's Avatar
the switch is at the bottom of the steering column on the back,..it is operated by a thin rod that is attached to the blinker arm and runs down the column and activates the switch
1961 c10 longbed - gone
1964 c10 swb
joe dirt is offline   Reply With Quote
