Old 11-16-2015, 11:25 AM   #1
dubie
dubie's Avatar
brake issue 80 Blazer
The brake light has been on since we brought this truck home. The previous owner had a rear brake line blow out on him so we replaced it along with a bad front line and the master cylinder, then bled the system out. The pedal still has weak pressure and the pedal won't engage the brakes until 4" from the bottom. Would that rear brake line blow out cause and issue in the proportioning valve? If I slam on the brakes, the front ones lock up while the rear don't seem to engage. There was fluid coming out of the rear bleeders but not as much as there was up front.
Any ideas boys?
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 11-18-2015, 09:42 AM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: brake issue 80 Blazer
Did you get it resolved? Here's a link that came to mind about the proportioning valve: http://67-72chevytrucks.com/vboard/showthread.php?t=656246
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 11-18-2015, 11:58 AM   #3
dubie
dubie's Avatar
not resolved yet. I'm going to bring it back in tonight and check the prop. valve. I'm getting fluid out of the rear bleeders but not near as much as the front. I'm going to crack a rear bleeder and have someone depress the pedal and see if that forces fluid to the line. It has the stock Prop valve in it so I'm not sure if it has the bleeder pin
