Old 11-16-2015, 12:49 PM   #1
scuderia
scuderia's Avatar
327 what flywheel and clutch?
Collecting all the parts to swap from my current 292 to a large journal 327. I just read that the flywheel on the 292 is different than the small block V8's. What flywheel and clutch should I be looking for? I'm going to keep the SM465. Also any potential issues with the bell housing I currently have? Thanks
'66 C10 SWB
'64 C2 roadster
'38 Indian Scout Flattracker
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline   Reply With Quote
Old 11-16-2015, 01:18 PM   #2
jtrichard
Re: 327 what flywheel and clutch?
Bell housing will bolt right on as for the flywheel every thing I read says it will also fit as long as yours is a "292" smaller 6s had smaller bolts and will fit the 327 if you drill them out.... as for the clutch if yours is 11" then it will also be fine
jtrichard is offline   Reply With Quote
Old 11-16-2015, 01:49 PM   #3
Chevy Fleetside
Chevy Fleetside's Avatar
http://www.summitracing.com/parts/pi...et?prefilter=1
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 11-16-2015, 02:15 PM   #4
scuderia
scuderia's Avatar
Originally Posted by Chevy Fleetside View Post
Thanks! and that'll work with the starter I have?
'66 C10 SWB
'64 C2 roadster
'70 Triumph T120R
'81 Laverda Jota
Old 11-16-2015, 07:27 PM   #5
Chevy Fleetside
You could count the teeth on the flywheel you have now. If you have 168 then it will work.
