Old 11-16-2015, 02:36 PM   #1
daniel.wood615
72 C-10 Steering column brackets
I'm restoring a 72 C-10. The steering column is not original - probably early eighties. It's loose and sloppy and poorly mounted. I'm replacing the column but I'm fairly sure that the mounting hardware that attach the column to the base of the dashboard is incorrect/missing/rigged. I have searched the usual sources for parts but can't find any source for the hardware and I'm not really sure I know what to look for.
Could anyone advise me of a source for parts or photos of where the column attaches to the base of the dash just below the instrument cluster? I've tried LMC, Brothers, Classic Truck Parts and SOKY.
daniel.wood615 is offline   Reply With Quote
Old 11-16-2015, 03:17 PM   #2
john
member #16
john's Avatar
Re: 72 C-10 Steering column brackets
DLtruck1973 has alot of brackets for our trucks. He probably has what you need. Welcome to the board.
http://67-72chevytrucks.com/vboard/s...d.php?t=665662
john is offline   Reply With Quote
