Old 11-16-2015, 07:30 PM   #1
chanclas90063
chanclas90063's Avatar
RE: Tachometer
Hello Group, I have a 1970 Chevy C-10 and the tachometer does not work. It looks like it is missing the needle. I purchased a new one from Brothers and when we pulled the bezel off, it appears that the entire back is sealed. Is it necessary to break the seal to install the new tach?? Thanks for any advice or suggestions...
Larry
1970 Chevy Pickup C-10 Dodger Blue
305CI/Th400 auto trans
Long Bed/Rally Wheels
chanclas90063 is offline   Reply With Quote
Old 11-16-2015, 07:42 PM   #2
michael bustamante
michael bustamante's Avatar
Re: Tachometer
love the screenname. my gramma was very accurate with her chanklas! haha
are you replacing a factory tach?
1967custom
michael bustamante is offline   Reply With Quote
Old 11-16-2015, 09:13 PM   #3
leftybass209
leftybass209's Avatar
Re: Tachometer
The instrument cluster must be partially disassembled to install a new tachometer. There is nothing "sealed" from the factory. There's a series of screws around the perimeter, the bulbs need to be removed so the circuit can be removed from the back, and it should be fairly self explanatory when you remove pieces as to the installation.
leftybass209 is offline   Reply With Quote
Old 11-17-2015, 11:40 AM   #4
chanclas90063
Re: Tachometer
I'm not sure if it is the original, but it appears to be original. I ordered an original replacement which appears to fit the bezel.
Larry
Old 11-17-2015, 11:44 AM   #5
chanclas90063
Re: Tachometer
If you are correct, then the cluster I have is not factory. When I removed the cluster, the back appears sealed with a thick plastic covering the back of all the instruments and is sealed. Maybe I will send this tach back to the vender and just purchase a complete replacement set already for immediate installation. Thanks for the suggestions and ideas...
Larry
Old 11-17-2015, 12:02 PM   #6
EARNHARDT#3
EARNHARDT#3's Avatar
Re: Tachometer
That's the flexible printed circuit board. Go ahead and take it off.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 11-17-2015, 12:45 PM   #7
michael bustamante
Re: Tachometer
can you post a pic of the front and back of the cluster? that would help alot
1967custom
Old 11-17-2015, 03:26 PM   #8
chanclas90063
Re: Tachometer
Sorry, the truck is a couple of hundred miles away getting an upgraded tranny. The consensus seems to be that the back is removable so that is what we will do. I almost retuned the tachometer but will hold onto it...
Larry
Old 11-17-2015, 03:36 PM   #9
leftybass209
Re: Tachometer
The original gauges don't look like any of the aftermarket gauges. You can take a quick look at a stock cluster. If your gauges don't look like them, then you have some type of aftermarket cluster. If your gauges resemble original style gauges, then they will disassemble easily.
They're easily identifiable because the numbers and letters are printed on the clear plastic lens, NOT on the gauge itself as you can tell with the new tach you purchased.
Old 11-17-2015, 03:42 PM   #10
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Tachometer
Look here for info:
http://www.earlyclassic.com/tech.asp...Tach%20It%20Up
Keith
Convert to disc brakes.
Old 11-17-2015, 05:16 PM   #11
chanclas90063
Re: Tachometer
This is great, thank you...
Larry
