Old 11-17-2015, 01:04 AM   #1
victorypark
Lightbulb Has anyone installed an LSA/LS engine into a 1963 C10 please.
Howdy all....
I'm writing from Melbourne, Australia and I'm about to undergo an engine transplant whereby I am going to exchange my existing 350 for preferably a 6.2 litre LSA engine.
I have searched considerably on a number of forums and performed endless google searches but to date no such luck on the above project.
I am just seeking the following information on those that may have successfully transplanted such engine, especially into a 1963 C-10.
The problem I have found thus far is that a number of companies make aftermarket kits for an LS/LSA conversion into a 1964 or later Chevy C10.....grrrrr.
For those in the know is there much, if any difference between a 1963 and 1964 engine mount/transmission crossover etc?
Any assistance would be greatly appreciated.
victorypark is offline   Reply With Quote
Old 11-17-2015, 03:49 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Has anyone installed an LSA/LS engine into a 1963 C10 please.
Do you have a pic of the truck? Since your in Australia, I'm not sure which version of the truck you guys received, as Euro and Export models sometimes had different switchovers for model year.
Does the truck have a torsion bar front suspension ?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-17-2015, 06:18 AM   #3
victorypark
Hi all.....I have attached some pics of my truck. I've had it for approx 18 months and I can't even tell you what rear end or transmission it is although I'm pretty sure it's a 12 bolt with a Turbo 400.
Further to the above it has a Porterbuilt chassis and Accuair 4 point air bag system with an Edelbrock crate 350 engine.
Old 11-17-2015, 10:43 AM   #4
Aruba1
That is a very nice truck. They are putting LSA engine in boats so it shouldn't be too difficult to put one a truck. What transmission are you looking to use? Stand alone harness or modified?
Aruba1 is offline   Reply With Quote
Old 11-17-2015, 01:26 PM   #5
MalibuSSwagon
Since you already have a 350 SBC, conversion is easy. Use 1" setback conversion plates (or standard plates if you need firewall clearance) attach your mounts from the 350 and drop it in.
MalibuSSwagon is offline   Reply With Quote
Old 11-17-2015, 02:59 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
HAHA you should have started with "I have a '63 on a Porterbuilt Chassis". Yea the LS motor will bolt in place of the SBC, providing you get a set of the mount adapters.
Trans xmember will depend on whether or not you use the setback plates, and whether or not you decide to run an o/d transmission. Generally, you can just slide the crossmember to the desired place a drill a few holes. With the PB chassis, you should still be able to move the trans xmember (but I'd honestly have to take a look at how PB is setting them up currently to know for sure).
Just make sure you have a good tuner. The LSA makes wonderful power, but you will need to make sure that you plan enough fuel system to run it, and a tuner familiar with boosted LS motors. My guess is between the Harrop guys and all the Ute/Commadore/Monaro guys down there, you should be able to find someone capable!
Old 11-19-2015, 05:02 AM   #7
victorypark
A big thank you to all those that have replied.
It is greatly appreciated, especially your tips BR3W City.
I figured coming on a forum like this will provide me with the necessary answers and information.
So has anyone out there in C-10 world, especially a 1963 year successfully transplanted an LS/LSA engine????
Oh and thoughts on PSI Prochargers as well?????
Cheers.
Old 12-23-2015, 02:41 AM   #8
DRTYRAT30
Jesse
DRTYRAT30's Avatar
That truck has a fresh rebuilt rear axle with a posi and 3.08 gears and all new bearing ect. The 350 engine was a GM crate 290hp. And a rebuilt turbo 350 trans. All fresh and broke in correct.
DRTYRAT30 is offline   Reply With Quote
Old 12-23-2015, 03:00 AM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Wait, was this your truck?
Old 12-23-2015, 11:42 PM   #10
DRTYRAT30
Jesse
DRTYRAT30's Avatar
Yes, I sold it a few years ago to a guy in Australia
