Old 11-17-2015, 01:26 AM   #1
SonomaComa
Proportioning Vavle for Disc Brake Conversion on a 1970 GMC C-20
I purchased a 1970 GMC C-20 that already had a Disc Brake Conversion. I was told that he used the Spindle and Calipers from a 1972 Chevy Truck. The Upper Ball Joint had to be changed too because the taper on it was different for the Spindle. It does not have Power Brakes. I was wondering about a Proportioning Valve.
There is some sort of Distribution Box that the Brake Lines from the Master Cylinder go into and then one line goes out to the Front Brakes and one goes to the Rear Brakes. There is also one more Brake Line that goes to an old fashioned Trailer Brake Controller, the kind with a slide handle inside the Cab.
Would it be best to just hook the brake lines up directly to the Master Cylinder and install an adjustable Wilwood Proportioning Valve on the Rear Brake Line just for the Rear Brakes and run the Fronts right out of the Master? http://www.wilwood.com/MasterCylinde...temno=260-8419
What is the purpose of that Distribution Box? Was that stock on a 1970 GMC C-20?
SonomaComa is offline   Reply With Quote
Old 11-17-2015, 01:49 AM   #2
Mmorgan32
Mmorgan32's Avatar
Re: Proportioning Vavle for Disc Brake Conversion on a 1970 GMC C-20
My truck had it. It's for the trailer brake controller. I took the junction box off( my trailer brakes didn't work) I left the controller on the inside. I like the way it looks. I just ordered a disc brake conversion. Hasn't come yet but from what I can tell and and what I remember of my 72 yes u run the lines from the master to the prop valve and then down to the front and back. The lines are different tho. I had to order a prop valve set of brake lines or u can make them
I think the trailer brakes were a dealer add on. Mines a camper and the gas tanks and everything were a dealer add on
1972 gmc c15 short bed... Sold
1970 chevy custom camper patina daily driver
Mmorgan32 is offline   Reply With Quote
Old 11-18-2015, 01:18 AM   #3
swamp rat
swamp rat's Avatar
You can get the proper distribution/proportioning valve from Inline tube, call them and let them know what you have. Or possibly order one for a 72 chevy truck from an auto parts store.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-18-2015, 06:32 PM   #4
SonomaComa
So You don't think the Adjustable Proportioning Valve is a good idea?
Old 11-18-2015, 10:05 PM   #5
Mmorgan32
Mmorgan32's Avatar
I wouldn't put an adjustable one on. My brother has one down on his frame rails of his camaro and he can't get it adjusted right. If u were racing your truck then I'd say go for it. I'm putting a stock one on my truck. It's all done for you
Old 11-19-2015, 08:57 AM   #6
72MARIO
72MARIO's Avatar
I have adjustable valves in my suburban and 1967 C20. No problem getting it adjusted.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 11-19-2015, 04:14 PM   #7
67chevemall
67chevemall's Avatar
I have a few of the cpp inline psi controls if you want to go that route.
2 on the front 2 on the back.
10 lbs on the fronts and 2 lbs on the back
I used a adj. port. valve and it was set perfect right out the box.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 11-20-2015, 11:32 AM   #8
SonomaComa
Wow those are neat. I thought I wasn't supposed to restrict the Front Brakes,
only adjust the Rear to the Fronts. But how does yours work, are they adjustable or pre set?
Old 11-20-2015, 11:45 AM   #9
67chevemall
I use the adjustable one.
The preset ones I was going to hide in the frame rail but chose not to use them
Free plus shipping if you want to try them
Old 11-20-2015, 11:54 AM   #10
SonomaComa
How did you adjust yours? Did you just drive and adjust it until it felt good? Or did you adjust it with by pressure testing it?
What should the pressure be at the Front Calipers and Rear Wheel Cylinders?
Old 11-20-2015, 12:08 PM   #11
Ruscal
I find it easiest to adjust the brake bias on a dirt road with winding turns due to less traction. If you brake going into a turn the rear end will hang out early if you have too much rear brake. Back off the rear bias until the truck holds its line when braking into the corner and you're good to go. Dry asphalt paving can hide minor bias problems that would cause problems when wet. Dirt roads simulate wet pavement.
Russ
RC
Ruscal is offline   Reply With Quote
Old 11-20-2015, 12:09 PM   #12
67chevemall
Stomp on the brakes and see what happens...should slide straight
Old 11-20-2015, 12:18 PM   #13
Ruscal
I think those inline valves are needed when your master cylinder is mounted below the floor. (Low) It keeps a small amount of residual pressure against the wheel cylinders or calipers.
Russ
RC
Old 11-21-2015, 01:03 AM   #14
SonomaComa
Russ
That is an awesome idea!
Old 11-21-2015, 03:18 PM   #15
davepl
davepl's Avatar
I have a factory 1970 unit kicking around from my drum brake C2500 if you get desperate. It's the nonadjustable unit but 1,000,000 factory trucks can't be wrong!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 11-21-2015, 03:19 PM   #16
davepl
davepl's Avatar
Actually that's not the point - even if it was way out of adjustment if you lock up all four, you're past the point of this anyway.
It's when the rears lock up during threshold braking; if they lock up too early, you'll bring the rear end around. Too late, they're not doing their share of the work.
