11-17-2015, 12:41 PM | #1 |
A-arms on stock front member
What are the good options for a-arms on a stock front member? Would like to run 20's front and rear and be as low as an ECE 4/6 drop. Of course want it to handle better also.
I like the ride tech coil over kit just so much more $$$ then I want to spend at the moment |
11-17-2015, 02:43 PM | #2 |
Diggin The SquareLife
Re: A-arms on stock front member
Arms are gonna be around 1100 for pb fab that uses coil spring, cpp also has some an djm has some arms but I would stay away from them
11-17-2015, 06:42 PM | #3 |
Why is one preferred over the other? Anyone speak from experience ?
11-17-2015, 07:50 PM | #4 |
motor exploder
If you're doing a 4/6 drop and stock crossmember, there is no real reason you need aftermarket arms unless you just want the look. You'll be better off focusing on replacing the balljoints, tie rods, bushings, getting a sway bar and some nice shocks than the 'bling' of aftermarket control arms. And yes, I do have CPP tubular arms (they are nice), and Hotchkis springs, along with double adjustable CA Chassisworks shocks. The arms are nice, but they aren't a 'must' by any means for a good handling, street driven truck.
I'm running 19's front & rear with a 5/7.5 drop if that matters.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
11-17-2015, 07:59 PM | #5 | |
DJM arms are a copy of OE w/a drop pocket for lowering. They make the already compromised scrubline on a lowered C10 worse. I would avoid them. CPP makes tubular arms that improve geometry & provide better ground clearance as the bushings are no larger than the barrel they fit in. I'm not sure what the bushing material is as the description lists it as "self lubricating, non-squeak, patented plastic". Stock or aftermarket sway bars are compatible. They offer coil specific or bag specific options & they're about $850 or so for uppers/lowers. Porterbuilt arms improve geometry & they have choices such as altering the wheel base 1" forward and/or narrowing track width. They can be used w/coils or bags (coils require a bolt-on adapter that's extra). The PB arms also require a spec'd sway bar vs any C10 aftermarket bar. They utilize Delrin bushings & are greaseable for maintenance which I like (I don't beleive any claim of squeak free hard plastic/urethane bushings). last I saw PB's were going for around $1,100 but vendors runs sales on them so they can be found for varying prices. There's the Ride Tech units that work w/bags or the Coil-Over spec'd arms. Which one's you choose decide what supporting gear you'll need & the associated costs. Don't forget about Hotchkis either..... I really like their products but if cost is a factor.....
11-17-2015, 08:10 PM | #6 | |
11-17-2015, 08:19 PM | #7 |
Scrubline is anything that can hit the ground below the wheel lip. Imagine a string pulled tightly from the front left to front right @ the outer edge of the wheel. That would be considered the scrubline. Anything below that imaginary line can contact the ground & cause damage and/or loss of control of the vehicle.
It is always advised not to allow anything to hang below that line. The rear end is the same thing. Anything below the lips of the wheels is possible trouble if it hits the ground (blow-out, object in the roadway, etc...).
11-17-2015, 11:47 PM | #8 |
Thanks for all of the responses.
The idea of centering the wheel in the wheel well sounds like a great idea. Also thinkin the better geometry offered would help reduce the amount of shims currently on the arm to get it aligned. Is porterbuilt the only one that centers the wheel? |
11-18-2015, 12:14 AM | #9 | |
11-18-2015, 01:46 AM | #10 |
Who's got the best deal on ridetech coilover kits?
11-18-2015, 01:49 AM | #11 |
Google their dealers to see.
11-18-2015, 08:09 AM | #12 |
motor exploder
It's kind of hit or miss with the RideTech kit centering the wheels in the wheelwells. They never mention building the kit to move the wheels forward, and in the thread below, it's kind of hit or miss where the wheels line up. In the first few shots, the wheels definitely look farther back to me, but in the shot of the yellow truck, they look centered.
http://67-72chevytrucks.com/vboard/s...=597074&page=4
11-18-2015, 09:28 AM | #13 |
We have a bunch of forum members that run our control arms on factory crossmembers, but here is a more recent one: http://67-72chevytrucks.com/vboard/s...d.php?t=605736
There are some detailed pics of the install and of the wheel placement before and after. He is running the narrowed and forward version. Feel free to send us an email with any specific questions you have! We would be happy to provide you with any information you are looking for. Sales@pbfab.com Thanks! Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
11-18-2015, 12:30 PM | #14 |
Stock crossmember and 1" forward and 1" narrow are Tha **** on my stock front member. Works like a charm no issues at all. PB is top notch with the tech and design plus customer service is tops in my book. I have had DJM control arms aka JUNK. I also have ran CPP better than DJM. But PB takes the crown IMO. I wish I would have gone PB to begin with and saved my ass a bunch off $$$. You get more caster and pulls the wheel in a inch best of both worlds. Straight bolt on no issues.
11-18-2015, 12:36 PM | #15 |
I'm hoping someone from ridetech will chime in on the center of the wheel? Is the ridetech arm also narrower? What's the advantage to the narrow arm?
Pbfab, sent your guy an email |
11-18-2015, 12:40 PM | #16 | |
IMO don't waste your time or money on the others. You will be happy with PB arms. I looked at ridetech also but all the positive on PB from this forum and the quality and craftsmanship plus the down to earth people Nate and Dave it was a no brainier for me. Last edited by RodsGreen10; 11-18-2015 at 12:47 PM. |
11-18-2015, 12:46 PM | #17 |
Also when you get the PB arms get the front shock relocators they are awesome and help the angle of the shock which in turn provides better ride. And prevents the old shock stud from cracking your frame.
11-18-2015, 12:46 PM | #18 |
Thanks everyone.
What spindle and drop spring works best with the porterbuilt narrow and forward arms on a stock member if I want to run 20's on the front on my 71 |
11-18-2015, 12:53 PM | #19 |
That would be more of a brand preference. Cause they will bolt up just like stock. I like WC and CPP. But that's just me. PB carries CPP so you could do a one stop shop with PB.
11-18-2015, 06:33 PM | #20 |
Here is some good info from porterbuilt. I asked if I got arms and decided later when money permits will running a drop member be an issue.
"If your plan is to run a Dropmember in the future you will need to stay with the standard or 1" narrowed control arms. We move the wheel 1" forward with our cross member so the forward arm will move the wheel to far forward. " |
