1950 disc brakes
installing speedway disc brake kit and my bearing apdaptor that came with kit just pushes on my spindles should be snug im assuming is there an option to snug this up
Re: 1950 disc brakes
i did machine maintenance for many years, we used LoctiteŽ Sleeve Retainer 640 for loose bearings
if the wheel bearing is sloppy loose you can pean the bearing surface with a center punch before application of the LoctiteŽ Sleeve Retainer 640 http://www.henkelna.com/product-sear...=8797924524033
cool, an ogre smiley Ogre's 58 Truk buildhow to put your truck year and build thread into your signature shop air compressor timer |
thanks
| Bookmarks |
