Old 11-17-2015, 08:55 PM   #1
Harleygolf1
BB motor mounts
Will I need to trim the frame rails in order to get these to mount?
Harleygolf1 is offline   Reply With Quote
Old 11-17-2015, 09:10 PM   #2
68bowtie
68bowtie's Avatar
Re: BB motor mounts
never seen that before. are you sure your main crossmember is installed correctly?
Old 11-17-2015, 09:26 PM   #3
Valarius_Starchaser
Valarius_Starchaser's Avatar
Re: BB motor mounts
I'm eyeballing the mount itself it looks like it is bent at the one bolt hole something cant be right aside from the mount don't go cutting her up just yet
Valarius_Starchaser is offline   Reply With Quote
Old 11-17-2015, 09:30 PM   #4
too much stuff
Roadtrip!
too much stuff's Avatar
Re: BB motor mounts
Factory BB mounts should bolt right in. Almost looks like you have it on the wrong side? Something isn't right...
67 gmc custom lwb dakota truck. Sold...And bought back... And sold again...
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 11-17-2015, 09:33 PM   #5
68bowtie
68bowtie's Avatar
Re: BB motor mounts
interesting. my truck is a factory big block with the original towers. were the frames notched like this from the factory?
Old 11-17-2015, 09:35 PM   #6
Harleygolf1
Re: BB motor mounts
Well I had small block motor mounts on the frame and just bought these from another member on here as my plan is the put a big block in the truck. Any other thoughts they certainly don't line up without trimming?
Your post tells me that I need to trim the frame rail?
Old 11-17-2015, 09:38 PM   #7
68bowtie
68bowtie's Avatar
Re: BB motor mounts
here's another pic i had saved of a factory big block truck. it sure seems like you need to trim the frame. i learned something new today.
Old 11-17-2015, 09:48 PM   #8
Harleygolf1
Re: BB motor mounts
Thank you, it looks like we both learned something!
Old 11-17-2015, 09:53 PM   #9
68bowtie
68bowtie's Avatar
Re: BB motor mounts
you peaked my curiosity so i did some digging. found a thread with some good info. my guess (i could be wrong) is you have a 67 frame. 68 was the first year of big blocks, the frames may have all been clearanced for both sbc and bbc engines 68 and up.
http://67-72chevytrucks.com/vboard/s...d.php?t=578644
Old 11-17-2015, 09:55 PM   #10
john
member #16
john's Avatar
Re: BB motor mounts
Your truck must be a 67. The 67's have to trim for BB mounts, BB's first came on 68 models.
john is offline   Reply With Quote
Old 11-18-2015, 10:36 AM   #11
specialtyretail
So,, what else you got???
specialtyretail's Avatar
Re: BB motor mounts
Originally Posted by john View Post
your truck must be a 67. The 67's have to trim for bb mounts, bb's first came on 68 models.
correct....
Our paypal is specialtyretail@yahoo.com Please DO NOTsend paypal funds as a gift, right is right. Thanks....
Sorry, we CANNOT ship larger parts. Thanks.
specialtyretail is offline   Reply With Quote
Old 11-18-2015, 11:16 AM   #12
chevyblue72
Re: BB motor mounts
I remember reading about the wider frames on the front of the 67's in a header fitment thread. Could that mount slip in and bolt from the underside of the frame.
chevyblue72 is offline   Reply With Quote
Old 11-18-2015, 11:58 AM   #13
Grin
Re: BB motor mounts
I know I'm new here, but have done a ton of framework. Make sure if you do trim the rails, you don't use heat, AND make sure you radius the cuts like they did at the factory. Sharp angles gather stresses, and then cracks...you don't want that.
Grin is offline   Reply With Quote
