11-17-2015, 09:53 PM | #1 |
What brand of gears are best?
I'm planning on a gear change for my 68 SWB FS and have decided on 3.42's. I need a posi carrier as well. It's been a long time since I bought gears and U.S. Strange is what used to be good but I'm not sure which brand of gears to buy these days. The posi unit I'm thinking of is an Eaton clutch style or the truetrack? Any suggestions would be appreciated.
11-17-2015, 10:53 PM | #2 |
Re: What brand of gears are best?
i used Yukon gears. 3.73:1 I already had a good GM 12 bolt posi locker.
1970 3/4 ton long box GMC !968 C10 short stepside (Papa's Old Lorry) 2006 2500 HD Silverado Duramax/Alison |
11-18-2015, 09:08 AM | #3 |
Any of the eaton posi's will do you good. I've got a set of richmond gears in my truck. Any of the big name guys will be just fine, and in all honesty if your your just cruising the truck really any set you feel comfortable with will be ok. Use quality bearings for the install and get the gear pattern right and you should be good to roll.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
11-18-2015, 03:06 PM | #4 |
Six in a row makes it go...
I went with Richmond. Seems to be working out OK.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
11-18-2015, 08:54 PM | #5 |
Looks good! What gears are you using?
11-19-2015, 06:04 AM | #6 |
That's actually the 5-lug 12-bolt I built for my '66 C10. I went with 3.08 since I have a Richmond 5-speed with a low first and 1:1 fifth.
11-19-2015, 02:53 PM | #7 | ||
"I ain't nobody, dork."
Richmond... period.
You'se gets what's ya pays for. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
11-19-2015, 09:22 PM | #8 |
I would say Richmond they have been the gear guys for a super long time. I will say that the Summit branded gears [I don't know who makes them for that label]I have had great success with them. I had several sets used in farm trucks and they held up well. For some reason I ordered a set for one guy and then the next thing I knew was 5 or 6 guys were dropping by my shop wanting me to order those gears for them. I told them they could load their credit card as easy as I could . So that being said I know that the Summit AND Jeg's branded gears are pretty dang good as well. I also know that the major diff[no pun intended] between the 2 wheel drive rears and the Z71 rear for the 99-04 rears were the posi and 3:73 gears. [you could order the 2 wheel truck with posi] but the 4x4's got the 3:72 gear. The 2 wheel rear at one time were bringing $750 while the Z71 rears would bring $1500[they still bring good money but not that much] I know a lot of the salvage yards would have a real high core charge so they could get out the posi, and order a new set of gears [like the store named above] and then turn a $500 dollar 2 wheel rear end into a $1500 buck 4X4 rear.[pretty sneaky]
11-19-2015, 10:08 PM | #9 |
Thanks everybody for the help and suggestions. After reading several posts on this site and others I decided on the Yukons. I know there are other brands that guys are using and have had good luck with and I've also learned that not all of these vendors make all of their own gears. Even Yukon! I'm a little anal about quality and Yukon SEEMS to be the gear of choice by several of the shops that install them. One thing I made sure of is that it wasn't just the profit margin that made this choice for them because these gears are more expensive than most. I also bought an Eaton posi so I'll be busy for the next couple of days.
Thanks again! |
