Old 11-18-2015, 09:55 AM   #1
jbgroby
jbgroby's Avatar
1960-66 Jack Inst. and parts
As many have been, I'm on a hunt for all the correct parts for the OEM jack that fits under the set in my '60. I have the brackets and ties down points as well as the springs. What I still on the hunt for is the jack and winding tools. There is one on eBay now but I feel its out of my price range (over $300.00).
In taking a close look at the Jack Decal, one thing I've never noticed was that part of the tools is a 'Tire Iron', This is not to be confused with the 'wheel wrench'. (see picture)
I've only seen the Jack, the wheel wrench, the winding tools; I never seen the Tire Iron - Learn something new everyday!
jbgroby is offline   Reply With Quote
Old 11-18-2015, 12:42 PM   #2
murdoc
murdoc's Avatar
Re: 1960-66 Jack Inst. and parts
I never noticed that tire iron in the picture before either!
I just ran out back and looked under the seat in my 65 for what I had thought was a complete set of jack and parts only to be disappointed to find it not there. I have everything else but that tire iron.
I will have to look and see if I might have one in my all original 66 custom camper...
murdoc is offline   Reply With Quote
Old 11-18-2015, 01:13 PM   #3
jbgroby
jbgroby's Avatar
Cool, funny how this has been over looked all these years.
Old 11-18-2015, 01:26 PM   #4
murdoc
murdoc's Avatar
Found what I think is the tire iron in my 66 custom camper.....
can anyone verify?
Old 11-18-2015, 01:54 PM   #5
pimpston65
pimpston65's Avatar
a
can anyone verify?
i have the same item, got on a pick awhile back.
pimpston65 is offline   Reply With Quote
Old 11-18-2015, 07:15 PM   #6
ImpalaJim
ImpalaJim's Avatar
wow wasn't thinking scrapped the jack and all its hardware. I made the floor smooth. so sorry I would have given it to you.
ImpalaJim is offline   Reply With Quote
Old 11-18-2015, 10:53 PM   #7
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
tire iron must be for split rim trucks, maybe it was only added when the split rim option was used?
Old 11-18-2015, 11:43 PM   #8
sodly
sodly's Avatar
I believe this is correct. I have the same iron in my original custom camper with it's original split rim wheels.
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline   Reply With Quote
Old 11-19-2015, 07:15 AM   #9
pimpston65
pimpston65's Avatar
I posted a pic of mine awhile back and one member thought it was used to pop the hubcap off, if so would it have been used on all models?
Old 11-19-2015, 09:12 AM   #10
jbgroby
jbgroby's Avatar
It's amazing that as long asany of us have been on the different BB's, its as if we learn something fresh every once in a while...... Of course this just gives us something to now have to add to the trucks.....
Old 11-19-2015, 11:14 AM   #11
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
The other end of the wheel wrench is used for popping the hubcaps off.
66 C20 Service Truck:
Old 11-19-2015, 11:28 AM   #12
jonzcustomshop
1961 crewcab
I am curious: on the bottom of JB's instructions it says " equipped with optional equipment only"
Are there more than one set of jack instructions? maybe one set for split rims, and a different set for solid wheels?
Old 11-19-2015, 12:26 PM   #13
1963c-10
1963c-10's Avatar
That is also a 1959 decal...wondering if anyone can post an original to cross check dates and decal #'s. Looks like this one was used from 60-63.....any idea if there was a change for 64-66?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 11-19-2015, 03:19 PM   #14
60-66
60-66's Avatar
Jake , looks like that 59 date is correct for your 1960 GMC. Heres one dated 1961 from a very low mile 1962 1/2 ton. I will look in a few more trucks. Im interested in seeing dates and part numbers from 1964-1966.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 11-19-2015, 03:30 PM   #15
jbgroby
jbgroby's Avatar
Cool, thanks
Old 11-19-2015, 04:14 PM   #16
1963c-10
1963c-10's Avatar
Only revision I can see in the 59 -61 sticker is the asterisk (*) for the tire iron being optioned. Interested to see what the 64-66 trucks had also.
I have some good pics of a NOS tire iron & GM part #....
Old 11-19-2015, 05:01 PM   #17
60-66
60-66's Avatar
heres an extremely low mile 1964 half ton fleetside.Dated instructions 1961.
Heres another in a very low mile 1960 C30 dated 1959, It also has the tire spoon.
Old 11-19-2015, 06:17 PM   #18
Fredthecat
The tire iron actually works quite well. Good for boondock work, now days folks just run to tire store.
The "pointy" end removes hubcaps as suspected or split rim lock ring.You can dent your forehead easy. The wide end used as pry bar to remove tire bead over rim AFTER breaking bead by using jack or vehicle weight. Like bicycle tire change with screwdrivers. I drive Jeep CJ left front tire slowly onto tire to break bead.
2 tire irons work much better, 3 even better.
I've done many Model A tires by hand with Chevy truck tire irons , baby powder and a plastic trash bag helps tire slide on/without scratching rims.
Harbor Freight tools sells cheap modern version 3 foot tire iron.
When I grew up in Alabama i couldn't figure why a truck needed a tar arn.
Fredthecat is offline   Reply With Quote
Old 11-20-2015, 06:51 PM   #19
ImpalaJim
ImpalaJim's Avatar
this is killing me when I was pink I couldn't want a hood for 6 hours and you can want a jack for 2 days and 10 hours so far. welp double standards every where I go!
Old 11-20-2015, 07:09 PM   #20
cv65
cv65's Avatar
might shuda had some wyre pliars to go with that tar arn! ha ha
cv65 is offline   Reply With Quote
Old 11-21-2015, 06:16 PM   #21
Liz
Catchy title goes here..
Liz's Avatar
Reporting the post to the staff would had been much more effective than whining and hoping they saw it. Thankfully after your email accusing us of such double standards, I took the time to search your posts and see what the issue was. Thanks for your help! Next time click report a post and quit trolling... an information seeking post is different than a wtb
thanks
Liz is offline   Reply With Quote
Old 11-21-2015, 07:51 PM   #22
jbgroby
jbgroby's Avatar
Huh, did I do something wrong?
Old 11-21-2015, 08:03 PM   #23
Liz
Liz's Avatar
I was replying to the person I quoted, not your thread. The subject is a good one and the information in replies awesome. I believe impala jim was simply annoyed about a previous issue and taking the wrong path to fix it. Its all good.
Old 11-21-2015, 08:15 PM   #24
Brad54
Brad54's Avatar
I just scored a complete original jack set-up today: I left the bracket and springs, since the springs were rusty, jack plates are common, and it just wasnt worth fighting under the nasty seat to unbolt it.
After reading this thread, I was REALLY hoping it'd have the tire iron too, but it didn't. Jack, crank handle, and three lug wrenches.
I don't know which lug wrench is correct though--anybody have some insight on identifying the right one?
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 11-21-2015, 08:32 PM   #25
PGSigns
PGSigns's Avatar
I have one of the tire irons posted above that has been in my tool box for as long as I can remember. Never knew where it came from. Thanks to the thread it must of come from one of the trucks I have had over the years. I also have a bunch of lug wrenches and don't know what is correct. So looking forward to info on that.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
