Front Cross Member Question ??
New Guy,I have a question concerning front cross member. When I bought my truck the PO told me that it had a 1976 front cross member. It has had power steering added at some point. It has drum brakes and I would like to change to disc. Are there any identifying marks or numbers?
![]() Join Date: Jan 2011
Re: Front Cross Member Question ??
Post a pic. No reason for it to have the 76 front cross member in it if it still has drum brakes. Pics of the A-arms will tell what it is. Look in the FAQ section above for what to do for disc. Cross member really does not make much difference.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
No cross member swap there. Just what your truck was born with.
Jimmy
Senior Enthusiast
The upper and lower control arms for the later disc brake spindles have rubber bushings on the inboard ends, compared to the metal type shown in the above picture:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
Thanks guys. That is what I expected to find out. Just looking for conformation.
Mark, do you know what year the control arms first came with rubber bushings from the factory in our trucks? Thanks
73 I think is the year they changed. Ball joints also changed.
Jimmy
Correct. 73 was the model year the bushings changed.
Thanks guys
