expert advice trailing arm swap
Ok here is what I need/got. I have a 72 blazer that I'm converting to 2wd and lowering. I ordered the trailing arm and cross member from ECE along with the 6" rear lowering kit. What I need is a the mounts on the frame that the upper coils go to along with the upper shock mounts. Does someone make a crossmemeber that mounts the shocks and the upper coil springs?
thanks guys.
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
![]() Join Date: Dec 2013
Re: expert advice trailing arm swap
http://nolimit.net/ Should have anything you need they are just down the road from me and everything is top quality .
I just saw this ad in the classifieds http://67-72chevytrucks.com/vboard/s...d.php?t=683069
| Bookmarks |
