Old 11-18-2015, 03:52 PM   #1
Zach079xxx
Zach079xxx's Avatar
Dome light bulb replacement
Im looking to replace th bulb in my dome light to a led style bulb. I don't want anything blue, white is ok though. What's the bulb size? The stock bulb is ok but I replaced the bulbs in my console I installed to leds and you can see the difference. Thanks fellas
85' GMC Sierra Classic
Built 350; Weiand intake, Holley 600, Thumpr Cam
Built 350 turbo with shift kit & 2500 Stall
Thumpin' away
Zach079xxx is offline   Reply With Quote
Old 11-18-2015, 03:59 PM   #2
83GMCK2500
Re: Dome light bulb replacement
It should be a 211-2 style and there are definitely color options depending on where you shop. Superbright LEDs for example.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 11-18-2015, 04:11 PM   #3
Zach079xxx
Zach079xxx's Avatar
https://www.superbrightleds.com/more...-44mm-car/237/ This the bulb? 5 bucks isn't bad at all. I'm thinking the white, the light blue they offer might be too much blue for my taste. - Zach
Thumpin' away
Old 11-18-2015, 04:59 PM   #4
TKCR
TKCR's Avatar
I put a LED bulb in the dome light & also under the dash (courtesy lights). You can see the light shining on the seat, even in the daylight. At night, they really light up the inside.
Old 11-18-2015, 08:35 PM   #5
Zach079xxx
Zach079xxx's Avatar
Do you have a link to the courtesy light? Those look great. Actually, do you have a link for both that and the led dome? They match really well. How bad was it wiring it?
Thumpin' away
Old 11-18-2015, 10:03 PM   #6
TKCR
TKCR's Avatar
Courtesy light kit from LMC. That will add two more lights.
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=191
Then the Dome light
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=97
Old 11-18-2015, 10:09 PM   #7
TKCR
TKCR's Avatar
And I also have these
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=73
Old 11-18-2015, 11:42 PM   #8
Zach079xxx
Zach079xxx's Avatar
Thank you sir. How did you go about wiring it? Follow directions or go about yourself?
Thumpin' away
Old 11-19-2015, 12:54 AM   #9
TKCR
TKCR's Avatar
The courtesy lights wire into the existing wiring for the light that's already under the dash, orange & white wires if I remember right. The door will lights will tap into the wiring that goes to the door switch.
When I get home from work, in the morning, I will look at the actual led bulbs and let you know what the part number is. I got them from the local auto store.
Everything was pretty easy to do, I'm actually a miss, not a sir��. So if I can do it, it's easy
Old 11-19-2015, 12:16 PM   #10
tucsonjwt
What happens if you step on the lighted bowtie in the plate? Will it break?
tucsonjwt is offline   Reply With Quote
Old 11-19-2015, 12:21 PM   #11
TKCR
TKCR's Avatar
I doubt that it would. But i don't step on it. Its made pretty sturdy
Old 11-19-2015, 12:42 PM   #12
Zach079xxx
Zach079xxx's Avatar
Oh I'm sorry, miss! It's just natural to expect a man, that's great women are into squares! And thanks for checking for the part number. I appreciate it
Thumpin' away
Old 11-19-2015, 12:45 PM   #13
TKCR
TKCR's Avatar
So the courtesy light bulb is a Pilot 1156, I got them from Oreily"s. I believe Auto Zone & Advanced Auto has them too.
http://www.pilotautomotive.com/led/IL-1156W-15.html
The dome light, I got off ebay
http://www.ebay.com/itm/2pc-White-LE...NTcTPv&vxp=mtr
Old 11-19-2015, 12:49 PM   #14
TKCR
TKCR's Avatar
Sent a PM
Old 11-19-2015, 06:40 PM   #15
travlinman
TKCR
how did u do the carpet on the back of the cab? Behind the seat. Is that on a cardboard back or something? What kind of carpet? Want to do something similar in my crew.
94 ls swap silverado
65 Pontiac
78 c30 crew cab dually (parted and gone)
82 c30 crew cab dually ( now building )
91 r30 crew cab dually (parted and gone)
69 swb-sold
71 lab sold
all in progress......__
..........._______ |__\__
..........|__(O)______(O)] ........................
travlinman is offline   Reply With Quote
Old 11-20-2015, 04:01 AM   #16
TKCR
TKCR's Avatar
Originally Posted by travlinman View Post
TKCR
I got a new cardboard storage tray from:
http://www.usa1industries.com/1973-8...tool-tray.html
I then used speaker box carpet to cover the tray. Attachment 1469070
