Anyone bought a new radiator lately?
So this will be my second new one in a year from O'reileys auto parts. Under warranty thank you but coolant is getting expensive to replace....72 1/2 ton 2 wheel drive automatic.
However now the replacement is raw aluminum with black plastic tanks instead of a thicker core metal tank like last time. Doesn't look really original at all....options?
![]() 70chevytruck |
Re: Anyone bought a new radiator lately?
eBay. I got a champion with dual electric fan for $160 or $180. Can't remember exact price. Works good. Truck don't run hot at all. I have the fans mounted to the front behind the grill and I've never even had to turn them on
1972 gmc c15 short bed... Sold 1970 chevy custom camper patina daily driver |
I've had this one for over a year, daily driver in 100+ weather, no issues.
http://r.ebay.com/Z2voUV
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
http://m.ebay.com/itm/Chevy-1968-197...859?nav=SEARCH
This is like the one I bought. I might of paid more than $180 for mine. It's been awhile. It's in my daily driver. Don't leak don't get hot at all
![]() Join Date: Jul 2015
Yes I had someone build me a new radiator utilizing an INDUSTRIAL FORKLIFT CORE.
My truck will barely make it up to normal operating temperature now, especially when I turn the heater on and watch the temp gauge drop 20 degrees . Yeas, I went the other route, ole skool, brass and copper, 4 core. I can still flush my system the real way with the proper chemicals that eat red oxide out of the block and not harm my cooling system with the exception of the lifetime water pump from NAPA. (Not A Perfect Accessory)! ![]() |
![]() Join Date: Feb 2009
The one I'm looking at costs $389. Per the seller, should fit right in.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Bought a Spectra(?) radiator that was supposed to be an exact replacement from Rockauto for about $165 plus shipping. The spot where the tank & core comes together is about 1/2 to 3/4 inch wider than the stock core so I wasn't able to mount it to my stock radiator mounts. I posted that here and I got a reply back saying they took out the rubber mounts and cut up some garden hose and put it in the brackets. That was a good suggestion & I tried it. It worked in helping to secure the radiator but it still sat about 3/4 inch higher because the wider size of the tanks would not allow the radiator to fit all the way down into the lower mounting brackets. The result was that the top shroud mounts are about 3/4 inch above the level of the mounting holes on the shroud. I kept the shroud at its original height by making these clips that I bolted to the mount and also mounted to the shroud below. (See picture)
I'm sure that someone smarter than me could figure out a more elegant solution. While I was trying to figure out how to make this crazy thing fit, I went ahead & took my original, 48 year old plugged up radiator to a radiator shop. He popped off the top tank, rodded it out, cleaned it up and said it was in pretty fair shape, especially for it's age and flowing really well. It cost me $146. I've already mounted the Spectra, scratched it up a bit trying to get it to fit, so there's no going back with it. I'll run it till it dies and keep my original. I'm posting this so others will know that 'exact replacement' wasn't the case with this radiator. At least on my old 67. Last edited by Freddo; 11-19-2015 at 01:45 AM. Reason: Tried to turn picture right side up. (Sorry, I couldn't figure out how.) |
![]() Join Date: Dec 2011
We make bolt-in conversion radiators and we also offer a forum member discount:
http://67-72chevytrucks.com/vboard/s...d.php?t=590670 ![]() We can build it for any engine set-up including the LS (no additional charge) and include a free steam port and built-in trans cooler if needed. |
#10 | |
Old member
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
