front shocks don't line up
Hi All,
I have a 1970 SWB with a 1972 front end (entire crossmember). The 1970 was drum, the 1972 is disc. When mounting the front shocks, it looks like the geometry is wrong! With the shock mounted on the crossmember (lower mount point) it looks like the frame mount needs to be further back on the frame (upper mount point). In order to get the shock on, I would have to bend the shock. Any ideas? BarryV |
Re: front shocks don't line up
Compress the shock a little and install it....... Is it possible the lower arm is bent??
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
![]() Join Date: Oct 2012
Take the bottom bolt back out, install it at the top first then compress the shock and guide it into the bottom bracket as it extends. Maybe that will help?
#4 | |
The shock is literally pointing upwards at the wrong angle. BarryV |
#5 | |
![]() Join Date: Nov 2004
It's also a pain in the ass to get the bottom bolt in. It looks wrong, but it's right... ![]() Also, if you have problems getting the bottom bolt in, put the head in a good pair of vice grips (attach them so the vice grips are "long ways" with the length of the bolt). The the bolt installed through the first hole, then lift up and wiggle to get it through the 2nd slot. Saves a lot of frustration and cussing. My bolt wouldn't go though without this.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
OP, I can take a picture of mine when I get home, if you want, so we can compare. I didn't have any trouble getting mine on at all, so I'm kind of curious what's going on. I have a 69 that I put a 72 crossmember on and did a 4" drop. I put the original length shocks back on it for a few days until the drop shocks came in. I swapped the drop shocks on it in less than 15 minutes and without removing the wheels/tires.
1969 Chevy CST/10 396, PS, PB, A/C |
I have a stock 72, and this is what I had to do to get the front shocks in. It wasn't terribly bad, but I did have to use some persuasion.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
![]() Join Date: Aug 2008
most shocks have a tie wire to keep them compressed until you need to install them. I always install the bottom bolt, then cut the wire and guide it on to the top stud. YOu have to be ready for it, as you only get one shot!
| Bookmarks |
