Old 11-19-2015, 10:37 AM   #1
RandyS8229
RandyS8229's Avatar
Rear gear decisions..
Hey guys, I've got an 85 c10 350/th350. I am in the process of a 90s 4" spindle lift. I've decided to go with 33s. My truck came with 2.73 in the rear. I just finished rebuilding my th350 and it's time to regear. I'm torn between 3.73 and 4.10 or 4.11 or whatever it is for 12 bolt. Anybody run a similar set up and want to share opinions? I only drive 50+ very rarely and for short amounts of time. Like 30 40 min on the interstate to orlando
85 c10 lwb 350/th350
Randy
RandyS8229 is offline   Reply With Quote
Old 11-19-2015, 10:41 AM   #2
RandyS8229
RandyS8229's Avatar
Re: Rear gear decisions..
If anybody wants to know it's a mild and tired 350. K1102 cam. Performer carb and intake. Poll like 8.2 compression. Headers 2.5 in exhaust. And probably poorly tuned.
Randy
Old 11-19-2015, 11:06 AM   #3
KQQL IT
At the body shop.
KQQL IT's Avatar
3:73 and 32's where decent In my 77, never tried 33's. Went back to low riders.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 11-19-2015, 11:14 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Has the rear end been changed? Your 85 didnt come with a 12 bolt, it should be a 10 bolt. Regardless of what axle you have, you cant go from a 2.73 to a 4.10 gear unless you change carriers too. I believe your 2.73 is running a 3 series carrier which will only accommodate up to a 3.73 gear. To go any lower you will need a 4 series carrier.
With that said, I think 4.10s would be a better choice if your running 33's and a TH350.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-19-2015, 11:44 AM   #5
RandyS8229
RandyS8229's Avatar
I am aware or carrier breaks and whatnot thanks. I have a 12 bolt from a early 70s truck in my garage I'm going to rebuild then swap rears. It has 2.76 gears in it now. The carrier break is 3.42 iirc. But I have found "thick" gears that will fit the 3 series carrier. Do you have any advice on using those?
Randy
Old 11-19-2015, 12:11 PM   #6
tucsonjwt
Of course, gas mileage will be affected by rear end ratio. When you are up in the high 3s or 4s your mpg will suffer. My choice has always been for the low 3s, even into the 2s, but I don't care about performance. If you want performance then you need the 4s, but highway driving will be limited. My squares have all ben 3/4 tons, so mpg is lousy with any rear end.
tucsonjwt is offline   Reply With Quote
Old 11-19-2015, 12:26 PM   #7
RandyS8229
RandyS8229's Avatar
Yeah I'm not worried bout gas mileage. I want that feel it in your balls when I punch it. But I also don't want it to be useless abovery 40mph lol. I've been driving around in 2nd gear the past couple days and it seems like it's running high rpms but I'm used to the 2.73 so I'm trying to get used to it. 2nd is 1.52 * 2.73 = 4.14 so it would be like 3rd with 4.11s. But I don't get the satisfaction of good launches so it's weird. Lol
Randy
Old 11-19-2015, 12:32 PM   #8
RandyS8229
RandyS8229's Avatar
With 28 (stock) tires and 2.73 is stock. So 20% bigger tires is 33. 20% lower gear to compensate is 3.27. But I want a lower than stock feel. Some came 3.08 stock. 3.08 and 20% is 3.69. With that 3.73 would be stockish feel as well. So I'm thinking 4.10. I wish I could find some 3.90 for 12 bolt. Happy medium. SO MANY NUMBERS!! lol
Randy
Old 11-19-2015, 01:10 PM   #9
rich weyand
rich weyand's Avatar
If you are changing out gears, I would go with 3.73 and 31" tires. To go 33" tires, you would really want a 4.10, and that means a new carrier as well, as has been pointed out. The BFG All Terrain TA KO2 just became available in 31x10.5R15, so you can go to the best tire out there if you are an all-terrain tire guy.
Now, if you find a 4.10 axle for decent bucks (good luck with that), then do the axle swap and go with 33s.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 11-19-2015, 01:42 PM   #10
wilkin250r
wilkin250r's Avatar
I've run several similar combinations. If you were like me, and routinely running 70mph freeway speeds, the 3.73 would certainly be better. I think you could easily run 3.73, but since you said you're rarely ever running over 50mph, the 4.10 sounds a bit better, but not by much.
My personal opinion would be, even though the 4.10 sounds better for your usage, I'd probably still opt for the 3.73 if it made a price difference with a new carrier.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 11-19-2015, 02:15 PM   #11
Mattchu60
I went to richmond gears site - these RPM's are at 60 mph:
- with 4.10 gears it would be 2500 RPM
- with 3.73 gears it would be 2280 RPM
Personally I would go with 3.73 gears.
Mattchu60 is offline   Reply With Quote
Old 11-19-2015, 02:47 PM   #12
RandyS8229
RandyS8229's Avatar
Would there be a noticeable difference in feel between the 2?
Randy
Old 11-19-2015, 07:02 PM   #13
hatzie
Moderator
hatzie's Avatar
I put a spreadsheet up on the service manual thread that takes all the fun out of it...
If you input your transmission ratios, axle ratios, and tire size it'll generate a table of RPMs to road speed.
RPM_Gear_Axle_Transmission_TransferCase.zip
This is a screen grab with the .ODS file open in Libre Office.
Libre Office will open XLS files too but there are formatting issues.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 11-19-2015, 10:09 PM   #14
bmchevy1979
bmchevy1979's Avatar
I currently am running 33s with 3.73 gears in my k5 and it does great on the highway but it lacks a little down low my motor has a little bigger cam than yours but with the gearing I can hit the freeway and do 70mph without issues. With the lighter chassis of a 2wd and your cam it should do just fine 4.11 you will be wishing you had overdrive at higher speeds. I'll end up going to them in my rig but I don't drive it on the freeway everyday anymore and it's a trail rig so I need more gearing down low
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 11-20-2015, 12:20 AM   #15
RandyS8229
RandyS8229's Avatar
Lol lacks a little down low with muncie. I have never hadone a 4x4 but 6 something 1st and 3.73 is 24 somethin 1st gear ratio. Mine is 6.88 total for first. Hence getting rid of 2.73s. I've been riding around in 2nd and I think 4.10 is a Lil low. I don't like the feel of 45. But the 2nd gear band might be throwing the feel off. It's a breaking band for manual 2nd right? So it would make it not coast so well
Randy
