Old 11-19-2015, 03:00 PM   #1
The Rocknrod
Moderator
The Rocknrod's Avatar
U-Bolt Mod - Lower Control Arm
Has anyone else complete the lower control arm 9/16" U-Bolt modification?
I seem to have no room to install the nuts properly. This thread in the FAQ section says to use a air hammer on the crossmember to make room. Is this what most people had to do? Cause I'm "thinking" about using a carbide grindning bit to make more room in the hole on the outside side of the crossmember. Thoughts, experiences?
http://67-72chevytrucks.com/vboard/s...d.php?t=599576
Old 11-19-2015, 03:12 PM   #2
ProudSoul
ProudSoul's Avatar
Re: U-Bolt Mod - Lower Control Arm
I was able to get the ones towards the cab side in but I couldn't get the ones towards the front in. I would like to know a good way to dimple the cross member as well. I have the other 2 sitting in the garage, at least one beefier one on each LCA is better that 2 skimpy ones
Also, when I did this I had trouble fitting the u bolts through the holes I drilled. I had to use a jack to bend the u bolts a little to get them through.
ProudSoul is offline   Reply With Quote
Old 11-19-2015, 03:26 PM   #3
The Rocknrod
Moderator
I used a large vice, they were spread a bit I'll agree.
Old 11-20-2015, 03:23 PM   #4
NVS-C10
NVS-C10's Avatar
I did the upgrade on my 63.. I'll try and get pics this weekend. I had no clearance issues with the nuts and the crossmember but I was careful when opening the holes that I kept them centered between the crossmember wall and lip.
NVS-C10 is offline   Reply With Quote
Old 11-20-2015, 10:08 PM   #5
racecougar
racecougar's Avatar
Ditto. No clearance issues, no grinding, no air-hammering here.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 11-21-2015, 12:03 AM   #6
The Rocknrod
Moderator
Did you use a socket to tighten them down? Or a wrench, I can make a wrench tighten them down but wanted to torque them.
Old 11-21-2015, 12:54 AM   #7
NVS-C10
NVS-C10's Avatar
I used socket
Old 11-21-2015, 08:37 AM   #8
The Rocknrod
Moderator
Must be a 64 thing. Even the panhard bar mount is better on a 65.
That FAQ article stated his was a 64 also.
Old 11-21-2015, 09:44 PM   #9
racecougar
racecougar's Avatar
A socket and a 1/2" drive torque wrench.
