Old 11-19-2015, 06:30 PM   #1
wilbur46
wilbur46's Avatar
downpipes
Hi guys,
My 65 LB has a nice 327 with straight 2" rams horns.
Since I have lowered it 5" I want all the exhaust above the frame and out to the rear bumper.
I have moved the trans linkage and have a new trans crossmember with plenty of clearance.
I'll cut holes in the trailing arm crossmember.
All this seems to be pretty standard , so the exhaust system must be common.
Who makes downpipes in 2 1/4" tubing that fit this?
Thanks,W
wilbur46 is offline   Reply With Quote
Old 11-19-2015, 06:32 PM   #2
chevy2tom
chevy2tom's Avatar
Re: downpipes
Take it to a local exhaust shop & have it made.
chevy2tom is offline   Reply With Quote
Old 11-19-2015, 06:33 PM   #3
PGSigns
PGSigns's Avatar
Re: downpipes
You are going to have to visit a local shop and have it bent to fit. Nothing off the shelf is going to work.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-19-2015, 06:53 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: downpipes
Originally Posted by wilbur46 View Post
Hi guys,
...Since I have lowered it 5" ...I'll cut holes in the trailing arm crossmember.
...Thanks,W
Hows your driveline (drive shaft) look at that height going through the crossmember?
Old 11-19-2015, 08:13 PM   #5
Evoracer
Re: downpipes
My 63 lwb is lowered quite a bit. Had my muffler guy route the exhaust on the outside of the frame rails from the ram horns all the way to the back. Oldschool sound with Brockman's. No clearance issues with the exhaust.
Evoracer is offline   Reply With Quote
Old 11-20-2015, 05:53 PM   #6
wilbur46
wilbur46's Avatar
Re: downpipes
Well, the quote was $500.
That's why I asked.
Since so many of the build threads make use of rams horns, and thru the crossmember routing, I thought someone would have been fabbing a whole system for this app.
Thanks, W
Old 11-20-2015, 06:02 PM   #7
TJ's Chevy
TJ's Chevy's Avatar
Re: downpipes
$500 is not bad at all. I dropped my GMC off to get exhaust work done...its stock stance with a 305 V6 and the quote was $400 with the mufflers.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
