heated mirrors
anyone here use them on there truck? also do you know whee to get them other then lmc? 130 is alot when you have a few of these trucks.
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
Collector of Projects
Re: heated mirrors
You didn't link anything to see exactly what you're talking about... so this may or may not work with your applications... But what about adding a heating element to your existing mirrors. Something like in the link below....
![]() ![]() OR ![]() ![]() |
Re: heated mirrors
I saw lmc had a set forsale when I was looking at mirrors im sure hes speaking about those. If I didn't have a all manual truck I would have looked into that more
1986 chevy k20 4inch lift 35 inch duratracs ![]() |
![]() Join Date: Oct 2014
Re: heated mirrors
Re: heated mirrors
i am talking about the ones like lmc i just cant justify 130 for them when i have 3 trucks to do. i wonder if you took the handle heaters and put them on the glass inside if that would work??? but can you even get to the glass with out braking it?
Re: heated mirrors
I've never tried them, I just wish they had more options. LMC offers both flat and convex mirrors, in a variety of finishes. If you want heated, however, you're limited to flat glass in a stainless steel finish only.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
Moderator
![]() Join Date: Oct 2008
Re: heated mirrors
ATV handlebar heaters get real hot. I have a set of inside the bar heaters on my Polaris and it gets too hot to grab if I'm not careful.
I'd be worried about breaking the glass on some cold day. You might try your local glass place. They may be able to get just the glass panels with heating elements for those stainless Dumbo mirrors like LMC is selling... only for a lot less. Then you could find a G series GM Van or a 94-01 Dodge Ram to pillage the electric dumbo mirror heads from.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
Re: heated mirrors
Sounds like a small price to pay for what you'll be getting. Maybe you could do 1 set a month. I agree the handle elements may break the glass and good luck getting them off.
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
Re: heated mirrors
The mirror glass is attached with a dab or two of silicone RTV on my mirrors. Pep Boys used to have just the mirror glass for replacement, but I have not seen them there the last time I was in the store. The GM factory I worked in where these mirrors were made used RTV. Mirror glass came from a company called Donnelly.
Moderator
Re: heated mirrors
I did a search because this is actually a useful mod for folks that are using their squares and T400 trucks for a daily driver.
Just because the ATV grip wide trace elements are too aggressive doesn't mean there's nobody making retrofit narrow trace mirror glass elements. I actually found some on Fleabay. These along with the electric mirrors from the G vans are a fairly quick update that doesn't look out of place. http://www.ebay.com/itm/UNIVERSAL-MI...-/121567345014
Re: heated mirrors
i have a old set of mirrors i can try to get apart
i think i will look into the matt and see what i can do if anything lol. some times i dont have good luck with this kind of stuff
Re: heated mirrors
I believe the tube that fits into the mount is hollow and you might be able to slide the heating elements into the tube... it might be enough heat to defrost the mirror via induction. Not ideal but better than breaking the glass.... on the other hand, the heaters and a new piece of glass is probably cheaper than the LMC ones...
#13 | |
Moderator
Re: heated mirrors
If you're going to heat up the whole cavity behind the mirror just put the ATV grip heaters on the metal backshell.
#14 |
In the Forgotten far North.
![]() Join Date: Jul 2007
Re: heated mirrors
I like my heated/power/turn signal mirrors on my burb.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
