Old 11-19-2015, 10:17 PM   #1
42_NATO
Gmc vs Chevy grills and lights
Who else likes the gmc grill vs the Chevy grill. I've looked around to see if anyone else has written up a how to. Long story short nothings out there or I didn't look enough lol. My question is how hard or how simple is it to replace Chevy grill and lights to a GM setup. If anyone knows of a thread started with this information and can lead me in the right direction please and thank you
42_NATO is offline   Reply With Quote
Old 11-19-2015, 10:48 PM   #2
Wilson!
Re: Gmc vs Chevy grills and lights
I did the opposite. I put a modded Chevy grill in my GMC. the holes in the front panel are different for the grill, the headlamp buckets and the headlamp harness is different. the top two bolt locations are the same, I put a bolt in those holes, and marked and drill new for the other two.
Wilson! is offline   Reply With Quote
Old 11-19-2015, 10:57 PM   #3
42_NATO
So if I just get a complete gmc grill with light and all, make new mounting holes and fab up the harness . or is it not that easy
Old 11-19-2015, 10:59 PM   #4
Wilson!
Yup. I ran my lights off a relay so I built my own harness.
Old 11-19-2015, 11:34 PM   #5
Clif Dzzzz
What type of relays did ya use for the lights.....
Clif Dzzzz is offline   Reply With Quote
Old 11-19-2015, 11:35 PM   #6
Wilson!
I used some generic automotive mini relays I had left over. I'm a Tech at a dealership, so I always have some extras.
Old 11-20-2015, 07:37 AM   #7
PGSigns
PGSigns's Avatar
It is a pretty easy swap. If you do the relay upgrade you can put new style lamps in and have the power to drive them. I have a GMC grill for my 65 and adding the holes was easy. The grill surround was marked using the grill and I found it was also dimpled from the factory in those spots. Should be a few threads in the FAQ section on the relay upgrade.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-20-2015, 08:19 AM   #8
42_NATO
Thanks I too read the relay post and that's what started my want to swap it out. I was stuck not knowing if i was going to be able to have working lights at first but nownibcan start looking for some parts and get it done.
