Old 11-20-2015, 02:08 PM   #1
datguy
Brake Line Plumbing help..
So Master Cylinder and Booster came in today, along with the 3/16 hard line and pressure valves i'll be running. now i just need the fittings to order.. can any one point out the fittings i need to put it all together? where the brake guys at?
This here is the master cylinder and booster im running..
http://www.ebay.com/itm/67-72-Chevy-...ZU57gq&vxp=mtr
datguy is offline   Reply With Quote
Old 11-20-2015, 05:29 PM   #2
ray_mcavoy
Re: Brake Line Plumbing help..
According to the ebay listing in your link
Master cylinder outlets are 1/2-20 UNF and come with adapter fitting for 3/8-24 and 9/16-20.
So it looks like you have a couple choices.
(1) The cleanest looking would be to purchase some 1/2-20 brake line nuts that have a 3/16" center hole. Put those nuts on the ends of your 3/16" hard lines, double flare the ends, and screw them directly into the master cylinder.
(2) If you are using pre-flared sections of 3/16" hard line, they'll most likely have 3/8-24 nuts pre-installed. In that case, you could use the 3/8-24 adapter fittings that are supplied with the master cylinder.
ray_mcavoy is offline   Reply With Quote
