Old 11-20-2015, 05:08 PM   #1
jojo
printing is my trade
jojo's Avatar
Booster broke any ideas?
My booster broke on install. I pressed the pedal and this thing popped out. Anyone know why?
Also is this fixable or should I just replace it?
Thanks for your input!
Jojo's '70 stepside build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=344184
jojo is offline   Reply With Quote
Old 11-20-2015, 05:49 PM   #2
Boog
laying low
Boog's Avatar
Re: Booster broke any ideas?
Damn son. How big is your foot?
I don't think I've seen that happen before. Is that an imported booster by chance?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-20-2015, 05:56 PM   #3
jojo
jojo's Avatar
Haha! I pressed the pedal with my hand while working under the dash the master cylinder wasn't hooked up at the time. I'm not sure where it was made. I got it from performance online.
Old 11-20-2015, 05:59 PM   #4
Boog
laying low
Boog's Avatar
I'd say hello POL, here I come.
Boog
primer is finer
Old 11-20-2015, 06:02 PM   #5
jojo
jojo's Avatar
Yeah, thats what I figured. It seems like that piece shouldn't be plastic.
Old 11-20-2015, 09:21 PM   #6
68panelman
68panelman's Avatar
It broke exactly for that reason, no master cylinder attached. There was no restriction of the cylinder bore, brake fluid=pressure, if nothing is there, she'll pop like a bullit
68panelman is offline   Reply With Quote
Old 11-21-2015, 12:18 PM   #7
hugger6933
Now on some later boosters I have had the rod slide out and I just put it back in before putting on the M/C of course, but it didnt have any pieces broken. that bakealite piece shouldn't have broken like it did I would call them and see about a return. Did you mash the brake [break in this case]pedal without the M/C attached? That or a bed rod or booster housing or bad bakealite piece would be the only possible causes.
hugger6933 is offline   Reply With Quote
Old 11-23-2015, 12:35 AM   #8
jojo
jojo's Avatar
Well, I got another booster from a different manufacturer. And with a little bad luck and in a completely different way, knocked the thing out again. Being and different design, the piece came out with nothing appearantly being broken this time. Can I just push it back in place and trust that it won't come out after assembling everything? It doesn't appear to have anything fastening it in there. Seems weird..
Old 11-23-2015, 06:45 PM   #9
cleszkie
cleszkie's Avatar
You really ought to install a master cylinder onto the booster before you push the brake pedal again.
cleszkie is offline   Reply With Quote
