Old 11-20-2015, 07:16 PM   #1
rubrduk
frame and suspension painting?
i'm looking at a some of the drop member type suspension systems which all come in bare steel...and yes there is an option of powdercoating, but i can't justify the expense given that it will be 1. for a daily driver, and 2. i live in a non-rust issue state 3. it's not going to be a show car
the questions: will a product such as POR15 or similar chassis paint be sufficient in strength, longevity, and attractiveness (simple and clean) for the purpose of the entire chassis and the new metal pieces that i will be driving on everyday in Los Angeles traffic and then dusting it off on occasion for a cars-n-coffee event
rubrduk is offline   Reply With Quote
Old 11-21-2015, 12:44 AM   #2
tinydb84
tinydb84's Avatar
Re: frame and suspension painting?
I used por15 initially. Did all the prep and it looked fine. Problem was it started lifting in places. If it got chipped the moisture would get under it and cause it to lift. I ended up removing it and painting it with 2k epoxy. I am much happen with it. This is what I short this weekend. It was done under my truck with a ****ty gun too.
David
Instagram: myfabguy
Old 11-22-2015, 07:00 PM   #3
rubrduk
thanks!
Old 11-22-2015, 07:16 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Even though its not going to be a show truck, consider powder coating. Find a local shop and have it done after you mock everything up. It will make you happy once its done.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-25-2015, 06:25 PM   #5
BIGglaSS
BIGglaSS's Avatar
POR15 is NOT a frame paint, like everyone is led to believe. POR stands for Paint Over Rust.
Epoxy paint is a better option, if you start with clean metal.
Being a daily driver, maybe a tractor enamel type paint is an option? I have never used it, but maybe something to look in to.
BIGglaSS is offline   Reply With Quote
Old 11-25-2015, 07:44 PM   #6
PGSigns
PGSigns's Avatar
I have had good luck with rustolium for painting everything from truck parts to tractors. Holds up really well and can look good even rolled on.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-25-2015, 08:25 PM   #7
tinydb84
tinydb84's Avatar
^^I might end up doing this in the future but I didn't want even thing to rust as I built it. I knew it was going to be a long process so I figured I'd paint it as I go so I can enjoy it a bit without it rusting.
David
Instagram: myfabguy
Old 11-27-2015, 10:14 AM   #8
earl84
I used a product called Hammerite. Cleaned up the framethe best I could and applied like POR 15. I think it looks great and has held up very well. Plus I bought it locally at a well stocked Ace Hardware. It is a rust encapsulating paint as well.
earl84 is offline   Reply With Quote
