Old 11-20-2015, 10:10 PM   #1
custom10nut
custom10nut's Avatar
Power brake booster braces
Could someone post a picture of a full stock set up on the power brake booster braces. When I did my conversion about 18 years ago, I pulled all the brackets and braces off the donor truck. When I put it in, I was in a hurry because I had to have it ready work work the next morning. I left one brace off with the plan to put it on as soon as I got the chance. Well now I have the chance and can't remember where it bolts to the firewall. The brace I speak of is about 18 inches long, u shaped channel, sort of lazy S shaped. On end hooked to one of the master cylinder mount studs, but can't for the life ome figure out where the other end mounts. Any help would be awesome.
P. S. I have a 70 Custom 10
custom10nut is offline   Reply With Quote
Old 11-20-2015, 10:23 PM   #2
davischevy
davischevy's Avatar
Re: Power brake booster braces
This is all I have for now.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 11-20-2015, 10:26 PM   #3
FirstOwner69
FirstOwner69's Avatar
Here's a thread link, but I thought only the disc brake 71s and 72s used the braces. Was the conversion on your 70 you mentioned to front discs? If so, you'll need to drill a hole.
http://67-72chevytrucks.com/vboard/s...=booster+brace
EDIT: Added picture with dimple for hole location circled with chalk.
FirstOwner69 is offline   Reply With Quote
