not enough hours in the day
ignition lock replacement
I'm swapping tilt columns on an 81. The replacement column did not have a key. How do you remove the lock cylinder without the key. If I remember right the key needs to be in the accessory position to press the release to remove the cylinder.
65 K-10 Short Step 68 C-50 70 K-5 85 K-10 & piles of spare parts |
Re: ignition lock replacement
To answer my own question after I tore into the columns. The lock cylinder is held in with a screw behind the lock plate. Remove the screw and the cylinder slides right out.
That's what I was going to say but you beat me to it
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE |
| Bookmarks |
