Old 11-21-2015, 02:50 PM   #1
BKWARDS
engine mounts
Hello,
new member here. I am removing a 350 and installing a 250 Intg. head engine, (completely rebuilt and balanced) into a 1971 GMC C-10. (I prefer the simplicity of the 6 Cyl. engine.) After all of the problems of the brackets A/C ect.. I am now having problem finding the correct engine mounts. I am including pictures of the mounts that came off the 250, and the two parts of the 350, one in truck. I do not know what mounts to use to install the 250. seeking advice.
Thank You
I hope I am posting this correctly
BKWARDS is offline   Reply With Quote
Old 11-21-2015, 02:55 PM   #2
boynton
boynton's Avatar
Re: engine mounts
The motor mounts in your fourth and fifth picture are the style you should use but without them in front of me I can't tell is the are for a 6 or 8 cylinder. They are very similar in size but if you have the correct mounts in the correct location it should drop right in.
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 11-21-2015, 09:11 PM   #3
396ci
396ci's Avatar
Re: engine mounts
i have a set of 6 cyl mounts cleaned and painted w/ flat black paint. they will need a touch up on the paint again. $45 shipped if your interested. thanks.
Brian
XNGH ECV Chapter 58
1972 Jimmy / Blazer Project 2wd
1974 Chevy Crew Cab Shorty
396ci is offline   Reply With Quote
Old 11-21-2015, 10:47 PM   #4
hamjet
hamjet's Avatar
Re: engine mounts
pics 1,2,3 are probably from a car 6 cyl. #4 will work with 6 cyl. stands in the rear xmember/frame holes 396ci shows.. pic 5 are 8 cyl stands in the 8 cyl xmember/frame holes.
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 11-22-2015, 12:05 PM   #5
BKWARDS
Re: engine mounts
is their a difference between the frame mounted part of the engine mount on a 6 Cyl. and an 8 Cyl.?
Old 11-22-2015, 12:11 PM   #6
396ci
396ci's Avatar
Re: engine mounts
hi russ,
welcome to the forum!
both use the same mounting holes but i believe the difference is the angle of the mounts and therefore v8 and 6cyl are different.
thanks,
brian
Brian
XNGH ECV Chapter 58
Old 11-22-2015, 01:37 PM   #7
hamjet
hamjet's Avatar
Re: engine mounts
Originally Posted by 396ci View Post
hi russ,
thanks,
brian
This is true, although I believe 6 cyl. and big blocks used the rear holes while the sbc used the front set of holes on the frame/xmember. In your 5th photo it shows sbc mounts in the forward holes. you need the 6 cyl. mounts bolted to the rear holes. (about 3 inches back).
Thanks, Joe..
Old 11-24-2015, 02:14 AM   #8
396ci
396ci's Avatar
Re: engine mounts
russ, i shipped the mounts today and pm'd you the tracking #. thanks again!
Brian
XNGH ECV Chapter 58
Old 11-24-2015, 04:47 PM   #9
72bowtiestepper
Re: engine mounts
That is correct...the 6 cyl. mounts use the middle & rear holes in the frame.
72bowtiestepper is offline   Reply With Quote
Old 11-24-2015, 04:51 PM   #10
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: engine mounts
Hello,
Thank You
I was just curious and wanted to pick your brain... how much simpler is an I-6 to a SBC? They are both some of the simplest designs on the planet when it comes to troubleshooting and working on them mechanically.
Anyways...just curious as to what makes an I-6 simpler than a Chevy small block?
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 11-24-2015, 05:05 PM   #11
hamjet
hamjet's Avatar
Re: engine mounts
2 less cylinders, 2 less pistons, 4 less valves, rockers, pushrods, springs, 2 less plugs 2 less plug wires, OHHH, forget it...LOL
Thanks, Joe..
Old 11-24-2015, 06:42 PM   #12
57larry
Re: engine mounts
I always liked the SBC over a 6
57larry is offline   Reply With Quote
Old 11-24-2015, 08:21 PM   #13
swamp rat
swamp rat's Avatar
Re: engine mounts
I like them both..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-25-2015, 07:28 PM   #14
BKWARDS
Re: engine mounts
Still on motor mounts
I just received item 3 in the first Pic. From rockauto they said it would fit 6 cyl. From 1965-72 and pickup's 71 &72. However it does not. The “B” measure on items 1 &2 is 3” on item 3 it is 31/2”. The “A” measure on 1 is 27/8”, and on 2 it is 21/2”, on 3 it is 31/4”. Item 2 is formed to compensate for the lower block leaning inward. #1 is pretty much vertical. I received the frame part of the mounts from 396CI.
Still looking for help, what goes onto the block?????
Old 11-25-2015, 07:30 PM   #15
BKWARDS
Re: engine mounts
perhaps I forgot the new Pics. here they are.
