Old 11-21-2015, 08:33 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
question for the Chevy encyclopedia, why for foam rubber between door panel and door?
71 C-10
Other than to ensure your panel doesn't remain flat? My LH door has it and the RH doesn't, which I'd bet is original. I can guess among a few scenarios.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 11-21-2015, 09:09 PM   #2
long67
long67's Avatar
Re: question for the Chevy encyclopedia, why for foam rubber between door panel and d
Anti rattle.
Mark
67 c20 custom camper
55 Olds 2dr hardtop
96 mustang
11 dodge nitro
long67 is offline   Reply With Quote
Old 11-21-2015, 09:13 PM   #3
71CHEVYSHORTBED402
Originally Posted by long67 View Post
Anti rattle.
Really, that's it?
I figured one or more of:
noise reduction
air reduction
pads the panel
I've also heard it was to keep water out of the cab.
Tony
Old 11-21-2015, 09:32 PM   #4
67swb72klb
67swb72klb's Avatar
Originally Posted by 71CHEVYSHORTBED402 View Post
Really, that's it?
There was a waxy type of paper water shield for that
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 11-21-2015, 10:35 PM   #5
FirstOwner69
FirstOwner69's Avatar
My 69 never had any waxy paper, plastic or any other such thing. That came later (possibly 1972?). It did have the foam seal pictured. If you look just above the foam in the picture, you'll see 3 elongated holes. The only reason they'd be there is for water drainage. Unlike today's trucks, these doors were very susceptible to water intrusion. The rubber squeegee-like things at the bottom of the door windows are primarily there to hide the gap between the window and door. They usually don't even contact the glass. Therefore, water gets in the door and through the access openings in the inner door. The foam keeps the water from leaking into the cab and the holes drain it back into the door where it drains out the holes at the bottom of the door. I've never seen the foam distort the door trim panels. Are yours steel or steel backed? I believe all, at least all prior to 72, were. I'm not sure about 72s or reproductions.
At least that's my theory... I see no other plausible reason
FirstOwner69 is offline   Reply With Quote
Old 11-22-2015, 12:08 AM   #6
71CHEVYSHORTBED402
Great explanation First owner.
The panels are a well made sheet of plastic. 1971
Beings the RH panel without a foam rubber strip is flatter than the LH with it, I can say near positive the foam rubber does distort the panel. If nothing to compare it to, then I can see why it would go overlooked.
My cab has been a real treat. Missing screws, etc. As far as I'm concerned, the RH door w/o foam is another example of poor workmanship from original. The only other explanation is the door was replaced before I got it, nearly three decades ago. Which is more likely?
Tony
Old 11-22-2015, 12:40 AM   #7
71CHEVYSHORTBED402
Cleaned these up today. Next time I see these it's a good day (i.e., done or nearly). Can't say I'm dissatisfied with the original cosmetics on the interior of this truck. Nearly all of it looks as it did new or real close. Seat excluded of course, it's thrashed.
Tony
Old 11-22-2015, 12:46 AM   #8
71CHEVYSHORTBED402
Sorry, couldn't help it:
Tony
Old 11-22-2015, 02:07 AM   #9
Clavo106
..nice.
Clavo106 is offline   Reply With Quote
Old 11-22-2015, 02:18 AM   #10
sameyrasmea72
sameyrasmea72's Avatar
This old original truck was a mess, but I am pretty sure this was the 1st time the door panel had been taken off.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 11-22-2015, 08:06 AM   #11
hamjet
hamjet's Avatar
Theres alot of road dirt and dust inside the gasket in the 1st photo, it looks like the gasket kept the outside area very clean.
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
