Old 11-21-2015, 09:10 PM   #1
ryans69chevy
68-71 bbc frame stands
Not sure what these bushings are. Figured they must go on the inside of the stand, but when I have researched this it seems nobody talks about these. Gm part number 3941744. Are these needed? I'm gonna use sbc motor mounts which people say you need a washer like a harmonic balancer washer to make it work, but it seems these make it so you don't need one.
Thanks,
Ryan
ryans69chevy is offline   Reply With Quote
Old 11-21-2015, 09:12 PM   #2
ryans69chevy
Re: 68-71 bbc frame stands
This is how I think they go. Am I correct? Prob just thinking too hard on this, but I haven't seen these before...
Thanks again,
Ryan
Old 11-21-2015, 10:22 PM   #3
hugger6933
Are the square rubber blocks the ones that are the rear motor mount for a stick shift truck that goes to the bell housing?
hugger6933 is offline   Reply With Quote
Old 11-21-2015, 11:00 PM   #4
ryans69chevy
Hmmm... Interesting. Trying to remember what mine looked like. I bought these frame stands from a board member a few years back and I received the stands, mounts, and these rubber blocks. So I assumed these were for the stands...
Old 11-21-2015, 11:40 PM   #5
68bowtie
68bowtie's Avatar
Thanks,
Ryan
you are correct, that's the factory installation 68-71. everyone talks about using the sbc mounts to save money, which eliminates the small backing parts. i'm not an expert, but common sense would say either way will work but using the original rubber backing pieces would probably dampen vibration a bit better.
Old 11-22-2015, 04:05 PM   #6
ryans69chevy
Sounds good to me. I'll prob just use them how I have them pictured!
Thanks!
