Old 11-21-2015, 11:44 PM   #1
kev63rod
kev63rod's Avatar
02 chevy lifter stuck in bore
so have a bad lifter in my 6.0. finally had a chance today to pull the heads to get at the lifters and of course that lifter is stuck like no other. its the exhaust valve lifter on cyl 3. it comes up a half inch or so then dead stops. so can i pull the cam with the lifter stuck in there? wanting to pull it then push the lifter into the cam area. is this doable without tearing the whole engine down? and also the exhaust valve smacked the piston. dont look like it was super hard but definitely left a mark. planning on changing the valve but was wondering if anybody had any idea what would make the valve hit the piston with just a bad lifter?
blessed are they that expect nothing, for they shall not be dissapointed
kev63rod is offline   Reply With Quote
Old 11-27-2015, 08:18 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: 02 chevy lifter stuck in bore
It sounds like it stuck the valve, as far as the piston witness mark? If you can pull the lifter up 3/8- 1/2 "....you should be able to slide the camshaft out. Figure ,that these (stock engines), are around .500 lift @ the valve, or a little under. That is with a 1.7 rocker ratio (IIRC), so the lift on the lobe is not that high As far as , can you push it out the bottom?.....you could on the Gen I, but I have not been deep enough in the ls based mills to say for sure? You might soak the lifter & bore, in carb cleaner & just work it (gently by hand). If its a varnish issue, it should come out the top. best of fun, Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-27-2015, 10:36 PM   #3
gofastwclass
The lifter can come out the bottom of an Gen III (LSx) block once the cam is removed. However that presents a secondary problem... now the lifter is in your oil pan.
gofastwclass is offline   Reply With Quote
